Dvd player fitment
Old May 6, 2009 | 03:46 PM
bukxanger's Avatar
Dvd player fitment
Will a JVC KDDV5400 dvd receiver fit in the little cubby under the nav screen? or should i just get the myron and davis receiver? i have an 06 w/ nav
Old May 6, 2009 | 11:35 PM
TISIXER's Avatar
I have the JVC DV7300 model, and it works well.
To answer your question, it would since it is a single din receiver. I would suggest getting a bracket from the OEM mp3 player attachment. Should cost around 80 from dealership.
Old May 7, 2009 | 02:40 PM
bukxanger's Avatar
thanks for the info
Old May 7, 2009 | 03:23 PM
racecarbox616's Avatar
Addict
Do you plan on playing dvd video though the navi screen with this unit?
Old May 7, 2009 | 04:34 PM
bukxanger's Avatar
yea.. i have the dom's nav2go also
Old May 7, 2009 | 05:01 PM
amadeus303's Avatar
TSX Sold! Hello STi!
I have (and had) 3 DVD receivers in my car, including the Myron & Davis AD212. Any single DIN receiver will fit w/ the MP3 attachment OEM bezel if you don't mind having your receiver out in the open. The AD212, however, and a few others will fit into the actual cubby itself and allow you to close the cover to conceal it when you leave your car... it's a great "anti-theft" solution. Also try the AcceleVision 9 series if that interests you...
One thing to keep in mind with the Myron receiver is that it doesn't have all of the function buttons on its face, so certain things require you to use the remote control. It can get pretty annoying. All of the Accele receivers can be used w/o a remote.
Old May 7, 2009 | 07:18 PM
xSteveO325's Avatar
anyone know if this would fit in a non-navi somewhere? pictures are always good
Old May 7, 2009 | 07:26 PM
ZildJonKim's Avatar
User with Skills
the dvd players that they mention will fit in the non navi as well since these obviously have the same cubbies. The problem you run into is, "where's your screen?"
Old May 7, 2009 | 09:40 PM
Addict
i know what the doms nav2go unit is...so just to clarify, all i need is a DIN and doms and im good to go right?
Old May 7, 2009 | 10:35 PM
TISIXER's Avatar
For the video, you may need a long RCA cable for the video feed
you just power up the HU and see if you can plug the audio RCA to your input aux. Some receivers doesn't have audio RCA output
Old May 7, 2009 | 11:10 PM
xSteveO325's Avatar
does anyone make any kits or is everyone doing this homemade?
Old May 8, 2009 | 08:22 AM
Addict
Thanks for the info....the doms nav2go is a must though correct?
Old May 8, 2009 | 02:04 PM
xaznperswaesonx's Avatar
p/n 08b06-sec-210 (2004-2008 tsx)
p/n 08b06-sec-220 (2006-2008 tsx)
Old May 8, 2009 | 04:18 PM
amadeus303's Avatar
Yes... or another comparable RGB converter... unless you know how to make one yourself...
Old May 8, 2009 | 04:22 PM
amadeus303's Avatar
Again... just want to point out to everyone that there are several media receivers that will fit *into* the cubby space compartment so that you can close the cubby door and conceal your player. You'd only have to make a hole to run your input/output wires. It's even better than a detachable face b/c people won't even know you have a media player in the car.
With that said, the MP3 bezel kit is clean provided you don't care about showing your player off...
Old May 8, 2009 | 04:54 PM
bukxanger's Avatar
where is the plug to plug in your ipod located at? the search did not help me at all..
Old May 9, 2009 | 03:37 AM
TISIXER's Avatar
did you mean for the aux? or a harness splitter? (via headphone jack)
Old May 11, 2009 | 03:10 PM
bukxanger's Avatar
aux
Old May 14, 2009 | 06:13 AM
TISIXER's Avatar
I think what you are looking for is in the center/elbow compartment (that little groove top of the power outlet), it is pretty well hidden
Old May 14, 2009 | 03:52 PM
bukxanger's Avatar
thanks..
Old Aug 14, 2010 | 12:46 PM
new_hampster's Avatar
I believe this has a typo. The 210 Kit is for 2004-2005 TSX.
Jul 16, 2017 07:33 AM
Fool
Mar 10, 2016 08:42 PM
adreano17
Sep 29, 2015 08:48 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
