head unit and climate control display and clock dissapeared??
Old May 4, 2007 | 09:40 AM
xtremelyslammed's Avatar
8th Gear
riding along in the tsx, put a jay z cd in the radio and i notice music hasn't started playing so i look down and my radio and a/c displays are both blank. the radio didn't want to power on at all, and a/c works fine except i cant see anythign on the display. i put in the code on the radio as a desperate attempt (you think of some crazy shit on long drives with no radio) and now my radio works as well, but no display? any one heard of this or had a similar problem? any and all help will be appreciated. thinking of swapping out head unit anyways but would love to be able to see a/c again?
Old May 4, 2007 | 09:50 AM
uncald4's Avatar
Former Sponsor
Sounds like a blown fuse again!
Old May 4, 2007 | 10:51 AM
Reach's Avatar
What year of TSX? There is a brand new TSB relating to older TSXs (04/05 I believe) and having the lights on your center console stack go out, but I thought that was only around the buttons, not the actual display screens too.
Check fuses, but if the problem persists, this might warrant a trip to the dealer.
Old May 7, 2007 | 11:36 AM
8th Gear
the tsx is an 04 with 52,000 miles.....i checked all fuses and they are good....i'm getting power to both radio and a/c, they both work fine, except that i can't see what i'm doing.....would this type of problem be covered by the dealer even though i dont have warranty anymore? i have no lights in the diplays, the buttons, or the clock!
Old May 7, 2007 | 12:56 PM
Reach's Avatar
Yes, the center console warranty was extended to 70,000 miles due to the number of failures on early models. This is going to be a dealer issue either way, if I were you I would already be headed there.
Old May 8, 2007 | 08:06 AM
8th Gear
Old May 8, 2007 | 08:12 AM
fdl's Avatar
fdl
Head over to the TSX forum and search. This is well documented and is all covered by an extended warranty.
Old May 8, 2007 | 08:16 AM
fdl's Avatar
fdl
https://acurazine.com/
Old May 10, 2007 | 05:54 AM
Gpump's Avatar
You want me to break it?
TSB to the rescue!!! I had the same problem, but mine was at 40000 miles - dealer even "blinked" at my modifications - main reason I will be purchasing another Acura in the future - they didn't hassle me at all.
Old May 10, 2007 | 12:56 PM
gavinn58's Avatar
STi'd
Just had that happen to my 04 as well. Dealer said there's a faulty control panel on the back that shorts out. Fix is to replace the entire head unit.
Old May 10, 2007 | 02:23 PM
fdl's Avatar
fdl
Actually with the new fix that just came out, they dont replace the entire head unit. They pull it out, replace something, and put it back. Unfortunately it takes alot longer.
Old Jun 6, 2007 | 09:29 PM
PianoSax01's Avatar
Have you tried pressing and holding the AUX button? It's an undocumented feature that turns on and off the displays for the radio and climate control.
Old Jun 7, 2007 | 09:07 AM
8th Gear
Fixed!
took to Acura dealer....even though ibought the car with 49,000 miles, they were still extremely helpful....fixed problem with display...working great for 2 days, then cd player stopped working.....they ordered me a new headunit, and when it comes in they are sending my old one to acura to get my cd's removed from it and sending them back to me.....best customer service ive ever experienced!
Dec 7, 2020 05:39 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Rob144
Sep 21, 2015 08:18 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
