having a problem with my subs blowing
Old Aug 1, 2002 | 09:34 PM
I have a '02 TL-S w/navi, I had a set of JL W3's installed and every two weeks they have blown, one time the amp shorted out, and one time they stopped going past a certain problem. I think all together they have put in 2 amps and 14 subs, I am convinced there is something not working right with the car and they just keep trying to fix it and failing and don't want to admit it. So I guess I just want to get some feedback from you guys on what it might be and what you would do in this situation. Thanks
Old Aug 1, 2002 | 10:03 PM
Beason's Avatar
mght be a bad install or u may need a cap
Old Aug 1, 2002 | 11:55 PM
962.5tl's Avatar
my guess would be a bad install... how would a cap help in this situation, all it does it give a little extra juice
Old Aug 2, 2002 | 02:49 AM
I have a full monster cap, I have an appt next thurs to get it all replaced again and they are building me a new cutome enclosure ( I think they might not have enough air) if they go again Im just gonna try and get my money back and go somewhere else I guess
Old Aug 2, 2002 | 11:59 AM
Beason's Avatar
Onlong with the extra juice, it gives it more steady flow of power, sorta of like a miniture surge protector. But since u do have on, its got to be a bad install. Whats the setting u have on your amp?
Old Aug 2, 2002 | 02:26 PM
randomwalk101's Avatar
Wow, JL is pretty hard to get blown unless you really crank it up all the way past its limits...if you blow it without cranking it up, your installation is majorly screwed.
Old Aug 4, 2002 | 11:41 AM
noleaf74's Avatar
I had the same problem w/ my RFs, i blew like 20 of them before i figured out that i should be breaking in the subs, try running them at half power for like a day or so and then go ahead and crank them they should be ok
Old Aug 4, 2002 | 03:34 PM
every time I broke them in for about a week just to see if that was it, I went to another place and had them look at them and they think the cutom enclosure isnt letting the subs breathe enough
Old Aug 4, 2002 | 09:24 PM
sssick's Avatar
Well is it a sealed or ported box? Is it the correct air space for the subs? Are they wired properly for the amp(4ohm, 2ohm....)? Most stereo shops have to pay for the defective item to be shipped back to the factory, so if the shop you bought your subs from sent back 14 subs at 20lbs a peice thats a pretty penny. I'm sure they would try to fix the problem, unless they are trying to get rid of old stock to get in the new stock.
Old Aug 12, 2002 | 04:27 AM
fixed it
It was the space, I switched from two JL 12W3's to one JLW6 v2 and it works perfect, Also I had to turn it around for some more extra breathing room, I highly suggest one very good 12 over 2 good 12's. It is a sealed box
Old Aug 13, 2002 | 08:57 PM
sssick's Avatar
Glad you fixed it, I think that two good subs in a properly built box with the correct air space, is better than one really good sub. Just my opinon.
SidhuSaaB
May 30, 2020 12:40 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Rachel Lu
Sep 27, 2015 09:53 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
mv01
Sep 15, 2015 10:36 AM
