ground wire
Old Oct 25, 2004 | 06:09 PM
uncleb's Avatar
ground wire
i got a question that i'm sure has a simple answer
whenever you hook up a system, each component of it has to be hooked up to the ground. what is this?? is it just hooking up a wire to any part of the chassis? i have a 02tl-s, are there specific ground points?
also, what the hell does this do? what's the point of it?
last - how do i connect the wire to the ground?
thanks for any info...
Old Oct 25, 2004 | 07:02 PM
Blazin_TL's Avatar
Registered User
when hooking up an amplifier.. [im assuming thats what you are doing], you can just ground anywhere in the trunk.. what i did was i grounded my amp around the aera where my spare tire was.. i took some sand paper to clean the surface. correct me if im wrong but when you have the power wire connected to the positive terminal of the battery the ground wire sends the outgoing power to the negative terminal.
<----- pts for me
Old Oct 25, 2004 | 07:37 PM
uncleb's Avatar
^^what is the POWER wire??
i'm actually installing a headunit right now, but will eventually install everything, (component speakres, sub, amps in trunk)....so let me know where to connect all parts
Old Oct 25, 2004 | 07:39 PM
phipark's Avatar
Not Asian
The purpose of the ground is to complete the circuit persay.
Make sure you ground to bare metal, scrape the paint if necessary. You also want the ground wire to be as short as possible.
Use a gold plated terminal to connect to a bolt on the chasis.
Old Oct 25, 2004 | 07:40 PM
phipark's Avatar
Not Asian
That's kind of scary, that you don't know and you will be installing it yourself. You must run a power cable from the positive terminal of your battery to your amp in the trunk.
Old Oct 25, 2004 | 07:52 PM
uncleb's Avatar
yeah, well, i'm kinda in the learning stage....which is why if anyone has any type of advice to give, i'm happy to hear, cuz its all news to me
i guess i knew what a power wire is, i just didn't know that is what it was called
Old Oct 25, 2004 | 07:53 PM
uncleb's Avatar
^^shit, i just realized, its just power wire, i thought it was like "power wire", like a specific wire with that name.....nevermind, i'm slightly out of it
Old Oct 25, 2004 | 08:59 PM
NYZGREATST's Avatar
Sig Rho's Finest
thas hysterical lol. but yea im assuming your doing a amp/sub install. just do a search for a more detailed anser but in essence.
a power FUSED wire from the battery to the rear of the trunk that attaches to the amp's positive
a ground wire that attaches the amp to somewhere in the trunk, bare chasis is fine.
remote ground wire from the amp to the headunit
rca's from the amp to the headunit.
pretty easy
Old Oct 26, 2004 | 12:18 AM
uncleb's Avatar
i don't get that one
Old Oct 26, 2004 | 12:50 AM
NYZGREATST's Avatar
Sig Rho's Finest
opps that was a type
its supposed to read
"remote wire from amp to headunit"
its the thin blue wire that will come with the amp kit. i think its a 16 guage wire.
emailnatec
29
Sep 28, 2018 04:27 PM
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
