ground wire
ground wire
i got a question that i'm sure has a simple answer
whenever you hook up a system, each component of it has to be hooked up to the ground. what is this?? is it just hooking up a wire to any part of the chassis? i have a 02tl-s, are there specific ground points?
also, what the hell does this do? what's the point of it?
last - how do i connect the wire to the ground?
thanks for any info...
Registered User
when hooking up an amplifier.. [im assuming thats what you are doing], you can just ground anywhere in the trunk.. what i did was i grounded my amp around the aera where my spare tire was.. i took some sand paper to clean the surface. correct me if im wrong but when you have the power wire connected to the positive terminal of the battery the ground wire sends the outgoing power to the negative terminal.
<----- pts for me
<----- pts for me
^^what is the POWER wire??
i'm actually installing a headunit right now, but will eventually install everything, (component speakres, sub, amps in trunk)....so let me know where to connect all parts
Not Asian
Make sure you ground to bare metal, scrape the paint if necessary. You also want the ground wire to be as short as possible.
Use a gold plated terminal to connect to a bolt on the chasis.
Not Asian
yeah, well, i'm kinda in the learning stage....which is why if anyone has any type of advice to give, i'm happy to hear, cuz its all news to me
i guess i knew what a power wire is, i just didn't know that is what it was called
^^shit, i just realized, its just power wire, i thought it was like "power wire", like a specific wire with that name.....nevermind, i'm slightly out of it
Sig Rho's Finest
thas hysterical lol. but yea im assuming your doing a amp/sub install. just do a search for a more detailed anser but in essence.
a power FUSED wire from the battery to the rear of the trunk that attaches to the amp's positive
a ground wire that attaches the amp to somewhere in the trunk, bare chasis is fine.
remote ground wire from the amp to the headunit
rca's from the amp to the headunit.
pretty easy
Sig Rho's Finest
i don't get that one
its supposed to read
"remote wire from amp to headunit"
its the thin blue wire that will come with the amp kit. i think its a 16 guage wire.
emailnatec
29
09-28-2018 04:27 PM
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
