Got the kappas in
Got the kappas in
Well they are in and they sound real good. Only problem is there is a slight hiss and alternator noise coming from the amp. What can I do to stop this. I think Radioshack sells some kind of noise filter but does anyone know if it will work??? I was a bitch to put them in. I had to cut a good bit off the door but I was still able to keep the 3 screw holes for the stock basket if I ever need. Also I have the crossover mounted in the door..do I have to worry about water getting on them or are they in a good spot??
It's all a matter of preference I'm sure. To me they sound great, especially for what they cost me. The Kappa tweeters are known to be pretty bright...combine that with the placement of the tweeters in the the pillars of the CL and it sounds even brighter. I have the treble on the head unit turned down slightly, but I have the treble on my amplifier (that's centered at 18khz) turned up.
skgarach
10-29-2005 11:48 PM
CLintheSTL
08-21-2005 01:35 PM
datboynamsays
03-09-2005 07:47 PM
