gonna get a few things, now wat?
Old Oct 28, 2003 | 12:11 AM
TL_Diplomat's Avatar
booooo
ok im buying a few audio things, so hat else do i need to get?
Purchasing:
Alpine cva-1005 indash Tv
Alpine cha-1214 12 CD changer
Alpine era-G320 equalizer
Alpine brain unit for add-ons
Alpine 12'' Type R sub (2ohm)
_______________________________________
Now i know i need the following @ least....
Box for Sub, Amp for Sub (600 rms)
DVD player/PS2
What type of wires should I use?
Do i need to Up-grade the Stock AMP?
metra dash kit should be around 30$ right?
Am I forgetting something?
Do i need more AMPS?
Could I do this myself w/ a friend?
Or should I contact Ron @ streeteffectz?
Last question, what do u guys think about putting a TV above the rear vent behind the center console?
THANKS IN ADVANCE!
Old Oct 28, 2003 | 08:19 AM
shawhite's Avatar
What type of wires should I use? monster cable, scosche, streetwires, phoenix gold, kimber kable, etc... depends on how much you want to spend.. personally i use streetwires cuz they are reasonably priced and good quality...
Do i need to Up-grade the Stock AMP? you will not be using the stock amp if you replace the stock headunit... and it depends on what door speakers you plan on going with to as if you will need an amp or not.. if you are sticky with the stock door speakers then you can probably use the amp in the alpine headunit..
metra dash kit should be around 30$ right? dont forget the wiring harness for 98 and up accords.. and if you plan on putting the eq in the dash under the flip out tv you will have to custom make a dash kit.. the metra is for single din only...
Am I forgetting something? door speakers, also you may want to rethink your cd changer... the cha-1214 will not play cd-r or cd-rws... look at the s634 (plays cd-r/rw and mp3)...
Do i need more AMPS? depends on what door speakers...
Could I do this myself w/ a friend? probably... but you will have to make a custom faceplate due to the fact that you are using a 2 din setup and metra only makes a kit for a single din...
Or should I contact Ron @ streeteffectz? if you decide not to do it yourself definately call ron since you are in jerzey...
i think this would be in the way if you put your arm on the arm rest.. i would reccomend either putting tv's in the headrest or doing a flip down...
Puma Jim
20
Oct 20, 2016 11:59 AM
rockyboy
Sep 23, 2015 12:02 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
V-tecAc
Sep 21, 2015 09:25 AM
