going beyond my skill level building enclosure.
Ive never tryied to build anything like this before. And I looking for ideas to make what Im trying to do work out. Im trying to put a 12" sub in each rear passenger side of the body. I got 2 complete layers of edead in the body and foam 6" deep anywhere air would leak,and plan to caulk face plate from inside and go over that with more edead.Then I also need ideas how to mold in my pannels.Here are some pics of what I got so far.I dont know if this will work or be a complete fail.just put a couple of screws to see if the sub would clear everything,it does....
To many cars in my garage
That is crazy I was thinking of doing that
Any ways I would go with all fiber glass in that area to strengthen it because I think that the pannel is going to move on the out side I would also use RF subs becasue they have alot of give with the amount of space in the enclosure.
I mean you could try doing it the way you started it may work if it sealed good but watch for the specs of the subs (enclosure space) some subs are not very forgiving with the amount of space you use.But you can use cotton stuffing to tune the sound
also if you are goin to use fiber glass make sure it doesnt touch anything it not suppose too!!!!!!!This maybe a good oppritunity to learn fiber glass because it hidden
For thw out side the only thing I could think of is custom moulded pannels . you guessed it more fiber glass !!
Are you wondering how to measure the volume of the enclosure, or how to adjust it? If you're wondering how to measure it, get a bunch of packing peanuts, and a box of a known volume. Fill the enclosure with the packing peanuts, then empty them out into the other box until it's full. That's 1x the volume of the box. Repeat this process until you don't have any more packing peanuts in the enclosure.
If you're wondering how to adjust the volume, you could fill it (the corners are the best place to start) like you were talking about with foam or whatever, then put more glass on top of it. That way, you'd have a good solid base for the internal edges of the enclosure...
Take the enclosure out of the car... Do the back panel(3-4 layers of glass and mat) in the car, then pull it out, and it should have enough strength to stand on its own. That's when you make your front piece, and you can make it to whatever spec you want...
If you want to do it the easy way (matt is not goin to like this) eyeball it and use a punch sub I did a couple of installs like this and I got good sound (not any thing crazy) but it took some insulation to tune it.
I used an MA audio sub with out the exact specs sounded like sh*t
Oh and Im saying all of this because I think unless you send alot of time and monney on this the sound is not going to be much better than good
To many variables
To many variables
Fluffy's right... A build like this is going to take a lot of time and effort and you'll learn a lot while you do it. The best way to learn is by doing.
I say leave the seats in there that way you know what you have to work around... Just put some of the blue painters tape over the seat so that if you get fiberglass on there, it'll peel off with the tape.
spoiler900
10-10-2015 06:48 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
09-25-2015 06:14 PM
