Footwell Lighting
Old Oct 5, 2003 | 08:56 AM
Mr Zipps's Avatar
Footwell Lighting
Im going to install neons under the driver and passanger footwells and also under the seats for the rear passangers.
I want to install them to so they light up when I open the doors. That is not going to be a problem because I will tap it into the dome light.
Here is the real question.. I want to be able to put a switch inside so I can turn on the lights while im driving....
Old Oct 6, 2003 | 04:02 PM
bdv687's Avatar
How is the easiest way to tap into the dome lighting? I was thinking about doing the same thing.
Old Oct 6, 2003 | 05:34 PM
bigmonkey70's Avatar
I would use a SPDT relay.
I would connect
terminal 86 to ground
terminal 85 to domelight wire positive source
terminal 30 to constant power source
terminal 87 to the to the neon positive wire
terminal 87a to a switch then also to the positive of the neon.
If you do it correctly, the relay should behave like:
when you open the door, the dome wire will energize the coil, terminal 85 and 86 and connect constant power from terminal 30 to the neon through terminal 87. At this point, when you open the door, doesn't matter if you have the switch on or off, the power won't route through 87a but to 87 instead
When you close the door, there is no power to terminal 85 so the relay won't energize the coil, power from terminal 30 will then be connected to terminal 87a. At this point if you have the switch on will turn on the neon or off to not turn on the neon.
Old Oct 6, 2003 | 11:13 PM
bdv687's Avatar
Post
I'm really not good with this kind of stuff...any diagrams ?
Old Oct 10, 2003 | 11:51 AM
nym31mp's Avatar
Rock Star
u wanna do that 2 i smell another project let me know it goes.......
Old Dec 3, 2003 | 12:42 PM
njtls's Avatar
I would connect
sorry to brign back an old thread...but i have a question...if i sue this method to mount a switch...doesnt the ground countrol wether the light is on and off....and the pos is always constant even to the dome?....or is that mehtod correct? shoiuld i follow exactly what he said to do?
Old Dec 20, 2003 | 10:59 AM
Bxscig's Avatar
Did anyone sucessfully try this?
Old Dec 22, 2003 | 03:57 PM
KaMLuNg's Avatar
need diode
Old Dec 22, 2003 | 03:58 PM
KaMLuNg's Avatar
if i had more time i would do it for u.. even w/ me getting outta school for break its farging cold outside and im working like madd... i live 2 towns over from u
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
