Focal Utopia -- Will they fit without a struggle?
In a 99 TL? If so, how thick were the spacers/baffles that you made? Any cutting to the door itself? A 4" magnet sure is deep!
Also, I noticed these were bi-ampable. Would I be better off powering these with a 4-channel amp, and power the rear coaxial speakers with the amp from my Alpine HU?
VP Electricity
1 Post
I have a hard time thinking about running Utopias in OEM locations, and a worse time with deck-power R fill : ) but I think I can safely say that you're just fine not bi-amping. There is a benfit to bi-amping, but it's usually in a pretty esoteric high-level audio system. WHat is the rest of your gear going to be again?
I guess it all depends on my front components but here goes:
Alpine 7897
Front: Focal 165W or 165KP
Rear: Focal 165CV or maybe something "less" than that for the rears
JL 450/4 (if i get the 165W) or JL 300/4 (if I go with the 165KP)
JL 500/1
JL 12w6v2
I've been hearing 100watts to the Utopias won't do the speakers justice, so I don't know if the 300/4 would be a good match?
Alpine 7897
JL 500/1
JL 12w6v2
The utopia's should have 150w driving them. Just remember, they lack midbase. I personally would not use them. I thought about it, researched it, talked to focal and decided against using them.
There are so many speakers comps out there to choose from that would be more apropriate for your setup.
I've heard good things about the Diamond HEX s600's (silk). I know, not comparable to the Utopia's, but half the price.
VP Electricity
1 Post
a/d/s/ I like, DLS I like, Morel I like, Alpine X-type is good, Rainbow is good, I believe the SEAS Lotus are good BUT HAVE NOT HEARD THEM : ) .
The DLS UP6 set has a 2" VC and a tweeter that plays mad low into the midrange. The magnet is inside the VC and as such they fit into Acura doors where the Morel and Dynaudio 6" do not. THey also make the Iridium and UR6S sets with 3" VC's...
Check dls.se for the UP6 components and check caraudio.com furm section under Speakers for lots of rave DLS reviews...
Ok, I'm going with the DLS Iridium's. Now for the rears (I know i'm going to get a debate on whether I should waste my money) Should I stick with the same brand? Are components in the rear not worth it, or do they cause phasing problems?
VP Electricity
1 Post
Might I suggest instead (in your budget range) using the Iridium 3-way set, and making kicks for the 3" dome mid and the dome tweet? It would sound MUCH better from a stereo imaging and freq response point of view than a system with R fill. I've heard this setup in an SQ champion car. THe kicks are much smaller than kicks using cone mids.
If you are asking if R components are not worth the cost difference to R coaxials (I'm not sure what you mean exactly) then it should be noted that R coaxials cause just as many phase issues as components.
Originally Posted by elduderino
Cool! Great sounding speaker.
As much as i'd like to get the 3 ways, i'm really against kick panels in general. My feet need all the space they can get
As far as the rears go, I like having that "fill". My alpine supports time correction, I dunno if this would eliminate/reduce phasing issues. Also, I will be running a Jl 300/4...how should I power the front/rears with this? Would I be better off with a 300/2 for the fronts and using the HU's amp to power the rears?
VP Electricity
1 Post
Same reason I don't have kicks, so I understand.
Two questions:
1) Re rear fill: Have you ever NOT had it? Not a 2-minute fader position, but have you ever gone without it for a good period of time?
2) Why spend the money on Iridiums, and then use deck power on rear speaks? Wouldn't that be the lowest common denominator?
Two questions:
I've had my rear speakers not work before... Man, I couldn't stand it, but maybe just because I wasn't used to it?
If I used the amp on the HU for the rears, it would be at about 1/3 the volume as the fronts...just to give it the fill effect and to give the listeners in the rear something to hear...I have many back seat riders.
Would I better off using the 300/4 for both the front and rear? I just figured that would be a waste of 2 channels if I'm not even going to utilize it's full power.
El Presidente
you could always brigde it for just the fronts
![Naughty](https://acurazine.com/forums/images/smilies/naughty.gif)
I have an alpine 7897 and the Focal Utopias up front and the Kevlars in the back.. I think it sounds great.. you may need to dynamat to get some stronger midbass..but it really bumps as it is..
emailnatec
29
09-28-2018 04:27 PM
