Flat Bose sub, question 4 audio pros
Old Nov 14, 2001 | 01:06 AM
NighthawkBlack's Avatar
I was wondering if there is any way to mount an aftermarket open air sub that works better than stock but fits under the stock grill. I know Infinity used to make Uniplane speakers with small powerfull magnets and they were only like an inch in depth but they don't seem to make them anymore. Hey Ron got any solutions? I see that the trunk springs are in the way. Has anyone overcome this?
Old Nov 14, 2001 | 03:25 AM
autophile1's Avatar
What is the actual mounting depth of the factory sub? Try the Illusion audio subs. Just a word of warning, I have no idea if they are recommended for free air use. I have heard them in proper enclosures howver, they sound really nice... here is a link to their specs:
Illusion Audio
Bryan
Old Nov 14, 2001 | 04:46 AM
shawhite's Avatar
i was thinking about trying to replace my stock sub with a free air sub....i remember seeing a post where someone managed to fit a pioneer free air in there with quit a bit of customizing....with out altering the car any there are only two speakers that i have found that might come cls to fitting....the illusion audio and then i found a planet audio sub that might work.....the planetaudio P10NEO 10" sub has a mounting depth of like 2 1/2 inches....if you do figure out a way to get it to work plz let me know.....oh by the way you can look at that planet audio subwoofer @
www.planetaudiousa.com
Old Nov 14, 2001 | 08:12 AM
StreetEffectz's Avatar
Well, you have a couple options.....I don't know HOW MUCH customizing you want to do, but.....
OPTION # 1 --- Remove BOTH tension rods from the lid and fabricate two actual "springs" so the lid opens and closes like the bars were there. This was, you have room to put a normal size sub in there with or without an enclosure. You will still need to make the opening bigger unless you are using an 8" woofer, OR, with the right size sub, you might get away with just a spacer.
OPTION # 2 --- If you don't want to remove the bars, you will most likely have to go with an 8" freeair sub, and custom make a mount that will space it high enough to miss the bars. I don't know of a really thin sub off hand, but if there is one, you can rest asssure that it's displacement will suck
Either way, you will have to make a new "cover" for inside the car.
Old Nov 14, 2001 | 10:58 AM
Angry
This sucks. I don't want to lose a lot of trunk space. Any way a sub can be mounted in the spare tire area an still have the doughnut?
Old Nov 14, 2001 | 11:08 AM
NSXNEXT's Avatar
With a lot of fiberglass it can. Might want to wait a little while till Ron gets to work on my car. I have a very small sub enclosure that he is gonna mount so I can remove it when I need trunk space, or at least that's the plan. After seeing Erinie's trunk, I am afraid.....very afraid.
BTW, CDT Audio subs can be put in some very very small enclosures. My 10" can be installed in a box of only .35 cuft
The 8", although never a SPL winner, can be in a box only .13 cuft
Old Nov 14, 2001 | 11:14 AM
Thanks that sounds good. I would like something I can easily remove. By the way how bad is the performance of those Infintybaselink powered sub add ons? I want better bass but I don't want a rattling car nor do I want to change the way it looks. I got all that out of my system when I did the audio for my old Camry.
Old Nov 14, 2001 | 11:46 AM
NSXNEXT's Avatar
I've heard they really suck. I thought someone on this board either got one or was thinking about it. Can't remember...
Old Nov 15, 2001 | 02:47 AM
Austin519's Avatar
"quote:
I've heard they really suck. I thought someone on this board either got one or was thinking about it. Can't remember..."
They're actually not so bad for what they were meant for. JL Audio also used to make a 6" free air sub, its now discontinued...but I have seen them floating around ebay...you may be able to find one and it should fit fine...
Austin519
TLDude876
Dec 28, 2016 03:18 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
