First time installed system** what do you guys think?
Old May 13, 2007 | 04:25 AM
daicacharco's Avatar
hey, well i've been working and saving up for my system and finally got it set up.
here i have
2 12'' JL w6v2 sub
2 Alpine MRP M850 amp
4k Kole Cap
KnuKonceptz wires and accessories
what do you guys think for a first timer as a 16 year old?
its in a 06 TSX with navi. im currently building a custom box to get more room.
i just finished building the frame and going to buy more supplies to put down the fiber glass will post up pictures for that soon when its done.
im planning on adding another amp and sub ;]
also im missing the w6 sticker on the right sub because it was thumping too hard ?
Old May 13, 2007 | 05:22 PM
G22_Powered_YA1's Avatar
well other than the fact that Im thinking you spent WAY too much on it, it doesnt look too bad, just tuck away some wires and you should be OK in terms of look............... but with a setup like that you cant use your trunk like at all, so its not really my taste............... but again not bad
what kind of headunit you running them to?????
oh and I do hope that you bought and/or have a high output alternator installed
Old May 13, 2007 | 06:48 PM
i bought 2 red top batteries and did big 3 and have no dimming or some sort. right now im building a custom box where it replaces the room of the stock spare tire and im going to have more room when im done with that.
Old May 13, 2007 | 07:54 PM
Tweek's Avatar
Caffenine Addict
I personally dont like the idea of 3 batteries. Its a little excessive IMO. The wires could have been run under the trunk carpet. Loom could have been used to conceal most if not all the wires, things could have been mounted in different locations to conserve safe, etc.
Overall I personally wouldnt be happy with that install. Its very messy, but considering its your first time its not TO bad.
Do some researching online and read how other people have done it. Look at pictures and see what a clean install can look like. If you have any technical questions feel free to PM me and ask.
Tweek
Old May 13, 2007 | 10:35 PM
thanks for the tips will pm you for help.
Old May 14, 2007 | 01:49 AM
Rapmaster0's Avatar
I just did my install, replaced all the speaker wire (including the driver's door, that was a bitch) , replaced all speakers (including tweeters), and added my 12w7 with a cap. It took long, but hopefully worth it. Now i am in the same position as you with wires around the sub like crazy since i have BOTH the 4ch and mono channel amp screwed on the box. I need to make it a lil neater but as an 18 yr old with his first big install, i didnt think i did that bad, and neither did you.
Old May 14, 2007 | 05:59 AM
heres a shot of my 1st install at 17, that lasted until I took it off for upgrades later down, now ive got a Polk MOMO 10: and plan to add another one in a dual box and keep the amps on the box, because I like practicality as much as I like good accurate bass
now 3 years later im in there wiring all my stuff inside as well, includes Headunit (came bafore all this), all my speakers, an integrated Bluetooth system (got pics on that if anyone's interested), trunk mounted CD changer and all its wiring.... all that is what comes to mind, once you get to know your car, it all gets easy
oh and if thats one amp to each W6 youre definately not properly powering them if youre running series at 8 ohms then youve got around 200W to each, and thats just waqy underpowering them, and if youre running them parallel at 2 ohms each, then theyre getting 800W a piece, and thats WAY too much...............
oh and I agree with Tweak as well, I mean if youve got a total of 3 batteries thats alot of extra weight, and as if the other components arent heavy enough, the batteries are definately heavy enough to mess with the weight balance of the car depending on where they are
Old May 14, 2007 | 07:30 AM
Tweek's Avatar
Caffenine Addict
Good tip with the wiring. Make sure your running the subs with the amps properly and at the correct ohm level. This will either make or break your system. Ive seen people try to run their subs which wernt able to hand a 1 ohm load and it just toasts the voice coil. If you do not know how to properly wire your subs to your amp or are 100% sure check out this link: Ohm Wiring
It took me about 5 minutes and I figured this out.
Alpine M850:
RMS Power (at 14.4V THD+N, 20Hz-200Hz)
Per channel into 4 ohms: 500W x 1 (0.08% THD)
Per channel into 2 ohms: 800W x 1
JL W6V2:
Cant find a spec sheet but seems everyone runs these at 4ohms.
So heres a little diagram that will help you understand if your wiring is correct:
That was right off the link I posted in this post on crutchfields site. Goodluck!
Old May 14, 2007 | 05:13 PM
JL says 500 or so watts is a good place to get power handling, optimal range is around 300-500.............. at 800W they say its into the "WARRANTY VOID" range, and at 200 is in the lower performance area, absolute minimum is 100W, but 200W is still underdriving
Old May 15, 2007 | 12:29 AM
so i should connect the wires from the amp to the ohm terminals to make it 4 ohms ?
Old May 15, 2007 | 01:31 AM
uncald4's Avatar
Former Sponsor
Tweek
What he said.
Old May 15, 2007 | 03:13 AM
you cant, its literally impossible to run a dual 4-ohm voice coil sub at a 4-ohm load (unless you only power 1 voice coil, and thats just dumb), it can only be 2 or 8, it can go to 4 but that would involve wiring both subs to 1 amp
Old May 15, 2007 | 10:25 AM
Tweek's Avatar
Caffenine Addict
Originally Posted by uncald4
What he said.
wow you agree with me on something...
Old May 15, 2007 | 03:25 PM
uncald4's Avatar
Former Sponsor
What can I say. You got a good eye for spaghetti.
skathe
2G TSX Performance Parts & Modifications
23
Apr 10, 2020 06:36 PM
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Skirmich
Sep 15, 2015 06:41 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
