fast blinker
Old Nov 4, 2002 | 12:18 AM
JakeCL's Avatar
fast blinker
so i recently cleared out my headlights and i put in some led sidemarkers and turn signal bulbs to replace the originals, everything lights up and works fine but my blinker goes real fast like a bulb is burnt out. has anyone else had this problem or tried using leds in our cars? i think its doing it because the leds use so much less current that the car thinks the bulb is burt out but im not sure. any suggestions or ideas?
Old Nov 4, 2002 | 03:19 PM
ReflexRacing_com's Avatar
URL Not Found!
I don't think I have your answer, butttt, it may be the BULB itself. My friend had me help her install blue highbeams on her FORD mustang, and then she asked me why her turnsignals were acting up. She turned one side on and it was blinking fast, the other one was blinking normal. she SWORE they come from same box...i dunno? fuse box? maybe?
Old Nov 6, 2002 | 12:02 PM
007 TL-S w/Nav's Avatar
NO I DONT THINK IT WOULD BE YOUR BULB THE L E D LIGHTS RUN ON A QUARTER OF THE WATTAGE AND IT CAN MAKE YOU SYSTEM THINK THERE IS A MISSING LINK IN THE SYSTEM. SO HOW LONG DID IT TAKE YOU TO CLEAR OUT YOUR LIGHTS, THAT IS A HARD TASK. DID YOU HAVE SOMEONE DO IT? TRY TO CHANGE YOUR FRONT BULBS WITH YOUR BACK BULBS AND SEE IF THAT FIXES THE PROBLEM. IF NOT YOU CAN WIRE THE SOCKET TO BLINK NORMALLY EVEN WITHOUT A BULB IN THE SOCKET.
007
Old Nov 6, 2002 | 12:30 PM
JakeCL's Avatar
i had some guy with no teeth help me clear out my lights but now one of them is leaking, how would i wire it to blink normaly?
Old Nov 6, 2002 | 12:43 PM
NSXNEXT's Avatar
It's definitely the bulb. Since the LED uses less power, the flasher unit thinks one of the bulbs is out. I've heard there is a way to wire something inline to trick the flasher unit, but I don't know what.
Old Nov 7, 2002 | 01:56 AM
randomwalk101's Avatar
add some resistors into that LED should do the trick for you.
Old Nov 7, 2002 | 04:37 PM
JakeCL's Avatar
ok the led is like 10 leds put together to fit in the 7740 socket that our turn signals are so im not sure how i would put in a resistor
Old Nov 9, 2002 | 08:30 PM
paper1122's Avatar
A-CL Fanatic
007, you mad or something? enough with the caps, it's so hard to read
Old Nov 11, 2002 | 12:31 PM
If that is the case, you can put the resister in the harness itself before the bulb. LED should last a long long time...but if you decide to go back to regular bulb, then just simply take the resistor out and resolder the wires together....goes like this...
(stockwire) ___________00000 (socket/bulb)
(stockwire) ______(resistor)____00000 (socket/LED)
Old Nov 11, 2002 | 04:32 PM
Paper, sorry i wont use caps anymore so its easier for you to read. Jake make sure you disconnect your battery or fuse before you add the resistor, or you will blow a fuse.
Old Nov 15, 2002 | 12:12 PM
JakeCL's Avatar
anyone know what resistors i should get as far as ohms?
Old Nov 15, 2002 | 12:40 PM
I would try 330ohm @ 1/2 watts...if the thing still blinks too fast, increase that to 470 @ 1/2 watts and go on up if still blinks fast. The reason we can't give the exact ohm cuz every LED is rated differently (voltage/amp)...and in your case, a bunch of them together..so you just have to try different values. BTW, resistors are cheap...you can get one from electronic store for like 4 cents a piece.
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
Frathora
Sep 28, 2015 11:29 PM
Froid
Sep 27, 2015 06:16 PM
