Factory radio
Factory radio
Is there a difference between the factory radios if one person has factory installed navi and the other does not? I just got a radio from a '03 TL-S (the one with the built in changer) and it only has 2 connections plus the antenna, but my '00 radio has the same 2 connectors, the antenna, and another smaller connector on the top part of the deck...
I believe the extra connector you are talking about is for the cd changer.
I don't know if 2002+ can add an extra 6 disc (kinda make sense since already got the indash 6 disc already) Anyone with 2002+ can confirm this
Looking through my ETM it seems there ARE 3 connectors.
Connector A: (Blue) - this is pretty much the power, speaker outputs, illum, and navi wires.
Connector B: (Black) - this is outputs goin to EQ
Connector C: (Blue) - CD Changer.
Seems as if the 2003 unit is missing my EQ connector B. I didn't plug in the new HU just cause i didn't want anything to short.
I have an 02 TLS Nav and I was able to add the Blitzsafe adapter and use the CD changer function as an aux input, so I believe that even with the in dash changer you can add an external changer.
Could the extra plug on the 03 have something to do with on-star? I am sure that it was available starting in 03 Navi cars.
Mark
Mark
Than the radio was off from a CL-S. Cl-S don't have EQ they use amp to power their speaker also CL-S come with tweeter also. But I assume you can put in After market amp to power your speaker just like installing an aftermarket HU but I am not sure about will you lost you NAVI voice....etc. Maybe a professional installer can help you more on that.
James
James
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
