Face covering
Old May 29, 2001 | 05:13 AM
AzNTL's Avatar
Post Face covering
what material should i use for my custom face covering. i have a gap now becuase im changing out my stock head unit and in the process of adding Cva-1005 and the 7863. also how would i go about of doing it too?
Old May 29, 2001 | 01:07 PM
StreetEffectz's Avatar
Post
There you go! Plastic with a coating of another material.
Old May 29, 2001 | 06:37 PM
Exclamation
That's how I made my switch panel in the cupholder: one piece of 1/16" thick ABS black plastic and another 1/16" layer of ABS in matching burlwood on top (will post pics soon). You can get ABS plastic sheets in any material you want - burlwood, walnut, brushed aluminum, carbon fiber black, blue & yellow - they're all 1/16" thick. And you can use a thicker backing of black ABS to support the new head unit - it comes in 1/8" and 3/16" thickness also.
Old May 29, 2001 | 11:29 PM
j83's Avatar
j83
Lightbulb
unless your a pro installer, i wouldnt recommend you doing it yourself, installers would use wood or plastic trim, matches and cuts it out and use rubber or vinyl type sheets to cover the wood or plastic...
you'll waste alot of time if you dont know what your doing,
just my nickel!
InFaMouSLink
Oct 27, 2015 06:52 PM
BIGxRED
Oct 19, 2015 10:47 PM
hashbrown
Sep 29, 2015 12:13 PM
