engine noise and reception
Old Sep 29, 2003 | 08:42 AM
03typeS6spd's Avatar
misanthropist
Last week I put in a set up of a single jl 10, and a mono amp, thanks to silverknights nice instructions the install was a snap, I did buy the cable link harness so that I didnt have to cut any wires, and I hate taking apart that car, it sucks compared to my three screw and the dash falls off accord...
Anyway, after I got it all installed I am getting some engine noise which wasnt surprising, but it is only coming from the rear speakers! I have the sub amp grounded to the bolt in the back that already had a ground on it, could this be the problem, I don't think it would be but I have some really good rca's, that are running down the separate sides, power left, rca right, and this is the fourth honda I have installed, the first bose though. Would the ground loop isolator help this??? I have never had to use one before. The navi seems to be working fine even thought the ten slams right beneath it but my radio reception sucks now!!! The antenna definetly got plugged back in and some stations work, but half my presets dont even come in now. I know silvernight is the resident expert but does anyone have sugggestions on the radio or rear speaker only noise???
Old Oct 1, 2003 | 04:11 AM
misanthropist
alright i moved, the ground and the radio reception went back to normal, go figure....
Old Oct 1, 2003 | 04:28 AM
SilverKnight's Avatar
Retired. Not available.
Good job
Old Oct 1, 2003 | 04:35 AM
misanthropist
silver, did you have to use a ground loop isolator or anything, i saw you asking a question in the other post, but most don't seem to have needed one and i am trying to figure out if i should get one or if it is a waste of time, thanks!!!
ps... it doesnt seem like any of the basslinks need them, but I don't think they are a full upgrade either so....
Old Oct 1, 2003 | 10:23 AM
Normally, you dont have alternator noise problem with sub since it's high frequency and the amp alreadys filter high frequency.
Old Oct 2, 2003 | 10:04 AM
misanthropist
does anyone else remember how they hooked up their cable link piece for behind the head unit. if so did you ground the wire coming off of the cablelink, I can't tell why i am getting the engine noise, and its driving me crazzzzzy
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
