E46 (bmw) install in dash....customized, Street Effectz style! PICS! :)
Pioneer AVD-W8000 8 INCH WIDESCREEN molded into factory trim, Icon DVD100 modified and molded into factory vents. We also sprayed everything ALUMINUM as well as the rest of the door trim ......
![](http://www.streeteffectz.com/fiberglass/alexdash1.jpg)
![](http://www.streeteffectz.com/fiberglass/alexdash2.jpg)
![](http://www.streeteffectz.com/fiberglass/alexdash3.jpg)
![](http://www.streeteffectz.com/fiberglass/alexdash4.jpg)
![](http://www.streeteffectz.com/fiberglass/alexdash5.jpg)
very nice!!!!!!!!!!!!!
That ... is awesome. How does it connect to the rest of the on board computer (OBC)? Through the normal iBus? Or did you have to split some wires? Also, how are normal controls (OBC, navigation, emergency, etc.) controlled? Can you still use the trunk Navigation system so that you free-up the DVD player up front?
Sorry for all the questions! This is the best implementation I've ever seen to date!
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
i very seriously doubt that this is tied in with the obc (on board computer) since this is simply a tv screen which is basically replacing the headunit... the pioneer avd-w8000 to be exzact... the screen is controled by the brain (either 8000r or 9000r) which is probably located either under the seat or in the trunk.... the brain will control all the head unit functions (ie, am/fm tuner, etc)... you could connect the pioneer navi to this and have it in the trunk if you wanted navi.... but truely i dont think that it is intergrated with the obc like a stock navi would be...
oh by the way Ron great work on the install... as usual...
Ah ... that's the part that I don't see. I was just wondering how standard controls are performed, since I don't see all the necessary keys. Thanks for the answer!
Originally posted by shawhite
... the screen is controled by the brain (either 8000r or 9000r) which is probably located either under the seat or in the trunk.... ...
WOW! Great work!
:wow:
Kevin,
Glad to see you like this link I sent you....now it's time to take your ride over to StreetEffectz to get some of your own custom work done on your M3!
-Matt
:wow:
Kevin,
-Matt
Matt, this is one of the best mods I've EVER seen. I just checked out their website and there are more pics. I can't believe that they are here, seems like a shop that only exists on CA or etc.
Originally posted by TL_LiFE
WOW! Great work!
:wow:
Kevin,
-Matt
WOW! Great work!
:wow:
Kevin,
-Matt
Originally posted by LSonDubz
Looks very nice! The only thing I don't care for is how the black around the dvd doesn't match.
Originally posted by StreetEffectz
The black around the DVD matches ALL the rest of the black surfaces in the car, including the guage cluster, and both vents which are on the same level in the dash. That's exactly why we did it, so it looked more factory
I dunno, in the pictures, it doesn't look like it matches very well, it still looks good, I would've probably sprayed it aluminum around it.
ExcelerateRep
12-11-2015 12:58 PM
nanos
11-12-2015 08:41 PM
