dvd Play with 2 monitor (help on outputs)
Old 12-23-2001 | 01:08 AM
AzNTL's Avatar
there is only one output for the dvd player.. how do i split up the outputs to use 2 monitors like the headrest monitors
Old 12-23-2001 | 01:34 AM
valuetl's Avatar
2 ways to do it. When you buy your monitor see if the hide away box for the monitor has extra outputs most do for another monitor. If they don't check the monitor itself for outputs for another monitor. Use can buy a add on box with you can control all your video if things get complicated also.
Old 12-23-2001 | 03:41 PM
StreetEffectz's Avatar
I'd just get a multi output video amp (around $50 or so) and all you do is plug the one output from you DVD player into it and there are multiple outs for other monitors...the one I have in the BMW has 7 outputs on it and they are amplified to keep the same overall signal strength going to each monitor.
Old 12-23-2001 | 10:38 PM
AzNTL's Avatar
Talking
Thanks for you help
Old 12-24-2001 | 10:04 PM
96TL's Avatar
Ex-Mod
If its only for 2 monitors then just use a RCA splitter. They cost like 3 bucks. I had that setup for a while. You wont lose video signal. If you have more than 2 monitors then you need a video amplifier like Streeteffectz said. I have one thats good for 9 monitors but I only have 5.
Old 03-23-2004 | 12:33 AM
Acuracy02's Avatar
運転することを愛
Only, heh...come on now, let's see 9.....
-Mike
Old 03-23-2004 | 09:12 AM
96TL's Avatar
Ex-Mod
All those TVs are gone now. My mother drives my TL now.
Old 03-23-2004 | 10:41 AM
vsokolov's Avatar
defently get a video amp most of the people wouldn't see that but if you split the signal I will be able to see that wideo suffers. Also goog quality TVs always have second screen outputs.
Old 03-23-2004 | 10:50 AM
Acuracy02's Avatar
運転することを愛
Let's say you were forced to make a decision, would you....
A) Purchase a video amp and split the video output signal from your DVD plater
or
B) Simply run the 2nd rear monitor off the output from the 1st rear monitor (given that you have high quality monitors which contain video outputs)
Let me know,
Mike
Old 03-23-2004 | 11:13 AM
96TL's Avatar
Ex-Mod
or
Let me know,
Mike
I would do B first. If your video quality does suffer just go out and get a video amplifier. My Icon unit was $150 (I think) but it was a little more than an amplifier. It was able to split the signal between 9 monitors from 4 video sources. It allowed me to switch different video sources for each monitor. Too bad I only had a DVD player and a rear view cam. You could make each monitor play something different. PS2, Xbox, DVD player, rear view cam, etc.
Old 03-23-2004 | 11:14 AM
96TL's Avatar
Ex-Mod
vsokolov, where's your shop located?
Old 03-23-2004 | 11:20 AM
Acuracy02's Avatar
運転することを愛
By chance do you remember the name of the company that manufactured the product you're describing?
Thanks for all your input,
Mike
Old 03-23-2004 | 11:52 AM
96TL's Avatar
Ex-Mod
The unit was made by Icon. Send an e-mail to info@streeteffectz.com and explain to them what you want to do. You can probably get a better deal since they have very competitive pricing. I got mine from a local stereo shop (stupid). You can check them out some of Ron's work at www.streeteffectz.com
Keep in mind a system like that requires a lot of wiring. It's not hard to do, but it can get confusing. Just keep your cool and plan it all all before.
Dom
Old 03-23-2004 | 11:56 AM
96TL's Avatar
Ex-Mod
Acuracy, I forgot to ask you something. How big are the monitors?
Old 03-23-2004 | 04:34 PM
Acuracy02's Avatar
運転することを愛
Haven't been purchased yet but will most likely be the new silver colored 6.5" Pioneers.
Michael
Old 03-23-2004 | 06:40 PM
96TL's Avatar
Ex-Mod
Okay. Try the Y-splitter and see what happens. If you lose video quality purchase the unit. The Y-splitter is only like $3 from Radio Shack so it won't hurt to try. Good luck and let us know what happens.
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 02:25 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
navtool.com
31
11-16-2015 09:30 PM
hashbrown
09-29-2015 01:13 PM
RadiantCycles
ZDX
09-26-2015 10:18 PM
