Dueling Alpine 10s In Firberglass TSX Trunk Boxes
Guinea Pig
Well I was gonna put my camber kit on this weekend, but I decided to do this instead. It sounds killer!
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_22_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_23_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_24_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_25_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_26_full.jpg)
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_27_full.jpg)
System: 05SSMTSXNavXM
Doms Navi/vid conversion
Alpine TV Tuner
Soundgate Aux3
Alpine MRV-F450
Infinity 6.5s
JBL 6x9's
2 Alpine 10"s
Alpine TV Tuner
Soundgate Aux3
Alpine MRV-F450
Infinity 6.5s
JBL 6x9's
2 Alpine 10"s
Cruising in ATL!!
That's by far the cleanest dual woofer setup I've seen!!! maddddd propz for that idea!! Did you do it yourself or get it done somewhere and if u so, how much was the installation? Only thin I would do differently if I ever go with two subwoofers, I would hide that amp or put something on top of it to protect it. I carry lot of stuff especially golf bags and it ain't amplifier friendly...!!!
Guinea Pig
I haven't completed my Amp set up yet that's why it's right there. I didn't want to cut anything. In this pic the mres are wrapped up in the material I used for the boxes. I don't want to cut anything for this amp settup since the MRV-F450 is most likely gonna have a little brother or sister soon. That single amp is running a 10 speaker system 2ohms per channel.
With this setup you can still install a flexible net to the 4 connectors in the trunk. That's what I plan on doing.
Guinea Pig
Originally Posted by jiggaman
that is EXACTLY the type of set up i want to switch to, i am getting tired of my box with 2 12s hogging all my trunk space.
Guinea Pig
The passenger side has a little more air space than the drivers side. There should be enough room for a 12 on that side for sure. Drivers side may be a little tight. I could have Squoze(should be a word!) some more air space out of both sides, but decided to make it fit this way. I didn't think there would be enough air space for a 10, but the low notes are nice.
Guinea Pig
You can fit golf bags in if you put half of the back seat down or if you take out one of the boxes. I haven't tried, so you might still be able to. I will try it when I get home.
Guinea Pig
YES GOLF BAGS DO FIT!!!
I put my set in there after work today. I will post other pics this weekend along with quick how I did it.
Also will measure the volume this weekend if I can. I woud like to know myself.
ChairmanMaoSaysRTFM
Originally Posted by CJams
Surprisingly, there are no major rattles. Those damn torsion bars rattle just a tad bit and thats it. It sounds pretty damn solid.
i would love to do this in my TL for a cleaner look, plus then i could have 2 DVC 10s
SSTS
3rd Gear
So whats the trick in doing this? very nice setup..... im looking for any and all ideas I have 01 3.2 CL I have (1) 10" KICKER SOLABARIC SUB that rocks but the box is too damn big. And again, Nice WORK!
Guinea Pig
I don't know the length of my golf clubs. I would say you could fit clubs for a person close to 6'. You would need to get some covers to protect the speakers if you want to haul a bunch of stuff around all the time though (or a net thingy)
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_31_full.jpg)
I will do a full write up with the basics to do it. I can't give all my secrets away, then my install would be the same as everyone else
. But here is a picture of the backs when I first pulled them out.
![](http://memimage.cardomain.net/member_images/4/web/832000-832999/832761_32_full.jpg)
Hey CJ, what do you have securing the subwoofer box to the wheel well? When you take hard turns, does it come loose at all? I'm considering a similar install but want to avoid it coming loose and destroying my trunk.
Guinea Pig
Originally Posted by t_dot_porkchop
looks real sweet!
you should really make a few in your spare time and sell them.......![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Originally Posted by elduderino
Yeah, CJ, you should do that... : )
These aren't "cheap." The construction process is a bit time consumming to get them to fit perfectly and to make them strong enough to take being abused by an amplified subwoofer consistantly.
Received 3,763 Likes
How much would you charge to make two boxes like that and ship them. I am looking to do a little more layed back look for my JDM car.
Guinea Pig
I was originally going to put a sub on one side and the amp on the other. So I made boxes for both sides to decide which side I wanted the speaker on. Then I got addicted to the dual set up.
I may replace the torsion bars with the gas springs later. We will see.
CJams,
Nice setup! I’d like to listen to your subwoofer setup since I also live in Washington. If it sounds good can I buy a similar custom enclosure from you? You mentioned that a 12” sub would probably work on the passenger side, that’s probably something that I would want.
Guinea Pig
What part of WA? Do you ever go to any meets? There is a little Mt. Ranier meet this weekend. If not, pm me and we can meet up sometime and you can take a listen.
Guinea Pig
Please Don't Ask To Buy My Boxes Or This Thread Will Get Locked And My Pee Pee Will Get Smacked!!!! If You Want A Similar Setup Drop Me A Line And I Can Tell You How To Do It Or Put You In Contact With A "legal" Vendor.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Very nice setup man, I'm in the process of designing a similar setup for my 1st gen cl trunk with 2 x 12's. Just can't decide which design I'm going to go with yet. Very nice job. The carpet makes it look REAL clean
