double din time!
#41
J-series addict
Firstly, I didnt read through this long arse thread soil I say something that's been mentioned or answered, SORRY!
I recently did a DD install on my 03 TL. Couple of things:
1. Change the factory speakers. You will truly be amazed in the difference of quality. I went with some Polk component door speakers for front and rear. Phenomenal difference. Besides, the stock door speakers are freakin cardboard!
2. If you have a factory amplifier for door speakers, get rid of that too. I bought a $100 Jenson 4 channel amp from CarToys and that made a big difference as well. This will require either jumping/looping input and outputs at factory amp or (the best method) running RCAs to your 4 channel amp (2 pairs) and run INDIVIDUAL speaker wire from the amp to each of the four speakers using a minimum of 16G wire. Factory speaker wire is ridiculously small and I'd be surprised if it carried and more than 50-70w!
3. Get the steering wheel audio control module if you didn't already. It allows you to keep your steering wheel controls and is (somewhat) easy to program. Most steering wheel buttons just send different resistances for different functions. The module simply intercepts this signal (which is practically useless to most aftermarket stereos) and converts it to a readable/interpretable signal. I initially used one for my stock steering wheel and then after doing an 08 TL-S steering wheel retro, was still able to use it again but had to reprogram due to the use of different resistances from the stock wheel.
4. Be sure to crimp, solder and heat shrink both powers and grounds that provide your primary supply to each amplifier you use. And don't be lazy, run both hot and ground all the way to the battery or distribution block. Most people do not realize when you attach a 4G ground cable to the chassis for supply grounding, you're starving and possibly damaging your component. Reason being is that the ground from the battery to the chassis is only using a 6g-8g cable so how can a smaller cable provide enough ground for a larger cable? Go directly to the negative post on the batty or the engine block which is usually supplied with a 4g or bigger cable. If you're trying to get it all over with and be done with it, run a 2g from the negative post to the chassis somewhere. But don't use and existing bolt or stuc and especially if it's a painted surface. Drill and tap a new hole in a part of the chassis that's a heavy gauge steel piece.
5. Don't ever assume that your factory charging system is adequate for whatever you throw on your car. Doing a load test at idle is the best way to determine (without full out diagnostics) if your alternator can hang or not. Turn headlights on, A/C on, stereo on and up, and even your flashers. Using a viltmeter, take a reading on top of the battery posts (not the terminals) and if it's reading atleast 13V after roughly 2-3 minutes of idle time, it's safe to assume that you're good and won't be stranded anywhere late at night when your battery dies because you neglected to do this test.
#42
Whats up with RDX owners?
Its recommended that a ground cable is as short as possible to minimize ground loops (also keep the power/ground wires away from the speaker/signal wires). Running it to the negative on the battery is about 10ft of cable.
#43
J-series addict
This would be the primary reason one uses large diameter cable all the way to the battery. You have to remember, a 4g or larger cable carrying MAYBE 20-25 amps (for sub and door speaker amps combined) at most will have absolutely zero resistance. If that were the case then remote battery setups would not be a practical install. If you are, however, talking about a cable or wire that's close to meeting its limits in terms of amperage your (civicdrivr) statement would have been true.
#44
Agreed!!!!
Also, if you wanna be able to play DVDs while driving(I know I do) you have to connect the parking brake to the ground in your harness. This tricks the safety feature in your deck to think its in park and "safe" to watch a movie.
#45
#46
J-series addict
Just because you've never seen it done doesn't mean it's not the correct way of doing it. In fact, the ONLY reason that it's done is because there is no high amperage power source in the rear of almost all vehicles. Here at the shop, when installing massive wattage systems this is something that's never done. Technically speaking (as previously mention yet somehow disregarded) the factory chassis grounding system will NOT support the wattage pulled by the components. Let alone supplying all that wattage PLUS your factory chassis grounding demands...ever wonder why they sell "hyper-ground" kits??? Hmmm?
#47
Proof read before you come off like a fucking asshole on the forum. Thats the #1 way to be sure you never get help from anyone. But then again, you clearly know it all, so you'll never have to ask. We shall all bow down to you, for we are lesser then thou
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
#48
k after much reading on the clarion they seem to be a big POS and many people experience all kinds of problems which i definitely dont want.
SO i wanna get a kenwood now, it's got the garmin gps which is just LOVELY.
the one i'm looking at is the dnx 5190, also comes with a backup camera with LIGHTSSS whaaat!!! i just hate having features that are not used on anything really. so i would like to get the camera, and obviously the sirius radio will be hooked up as well
http://www.ebay.ca/itm/Kenwood-DNX51...ht_4715wt_1101
what u guys think about that one??
so i need to get the steering wheel thingy (just ordered), and the sirius radio shyt, and then i should have everything i need.??
#49
J-series addict
Wow dude chill man. What's wrong with you and why are you getting so offended over an Internet based discussion? Will it make you feel better if I say you're right or "wow, look hot intelligent civic is with all of his Almighty wisdom and knowledge!"?
Anyhow, I do automotive electrical work on a DAILY BASIS. You are just a person who parrots unuseful information and if disagreed with or questioned, a arrogant disrespectful kid comes out to play. Hence your childish little attitude.
While ur crying about getting butthurt, I'll go back to making a much earned and deserved $40 an hour due to my accurate/experienced gained knowledge. As a man, you need to know when to lower your pride and say maybe you were wrong. Not react in such a way that's not only embarrassing for you...but it makes me feel embarrassed for you too! Lmao...wow.
#50
just bought the sirius reciever and antenna... damn there is so many things to get to make this all work..
the deck (which comes with the gps antenna, rear view camera, and mic which needs to be wired up), then the metra harness, the dash kit, then the steering wheel button integrator, and then the sirius unit which has an antenna as well... so i'll have two on my baby... damn.
man this is gonna be one EPIC day.. i love hooking up new shit in the whip.. hiding all the wires is so gratifying too... at least for me
#51
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Now, getting back to the our discussion, we were talking about ground wires. You said you ran it from the amp to the negative post on the battery. My response was to keep it short. Not use thin gauge wire, not use the factory ground system, or whatever else you can think of. Simply, keep the ground wire short. I assumed it was common sense that the ground wire wouldnt be a cheap little 8awg cable, but instead a nice 4awg cable (larger if you are running multiple amps and a distribution block - though Im sure youll twist my words here as well) to a clean, unpainted point on the chassis (again, common sense).
With that said, if Im wrong, Im wrong. I admit it, always have and always will. Im not here to make anyone think I know everything. Because I dont. Just like everyone else thats on here, Im here to learn. Facts or sources to back up your position help. Just saying "here at the shop....." doesnt mean anything to me. I, too, can say "they do it this way at shop XYZ". That doesnt mean its right. Present your side like an adult and youll get treated like an adult. Right now, you look like a pathetic e-thug.
Im done taking Progressions thread off topic. If you have a problem with me, feel free to PM me. I assume we can hash things out like grown men, not babies with a keyboard.
#52
i got 2 of them to put somewhere so.. we will see
still worries me tho cause the glass has to kill the signal strength... tho it may work but likely it'll be more prone to losing a signal. it can never be strong enough imho. i think i may just put them on the roof in a stealth fassion/ assiuming the cord is long enough
#53
J-series addict
Civicdrivr- it's all good man. Sorry we got off on the wrong foot. More over, if I pissed you off, it was purely unintentional. I'll man up here and be the one to say sorry not because any other reason than I like this forum and it's members. You've offered good advice as most here have. No reason for those of us with knowledge to argue or become irate when really nobody was even wrong. Hopefully that extinguishes any fires between you and I.
civicdrivr (05-04-2012)
#54
#55
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
![Popcorn](https://acurazine.com/forums/images/smilies/popcorn.gif)
#56
Alpine stuff, McIntosh MX406 + MPM4000, Nakamichi stuff, Pioneer 8000, Panasonic B Tube
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
#58
So I'll probably be doing a new head unit in the near future myself, but can't find a decent DIY for the CL. Does anybody know of one that exists? Also if I get the deck/dash kit/wiring harness, is there anything else I need? How involved is this process?
#59
The longest part is taking the dash apart. Wiring up the radio is easy as long as you can read a wire diagram. Just match up the diagram for the new radio with the one supplied for the harness.
BTW, one thing to note - If you want to make the install completely reversible (i.e. - no cutting wires) you'll need to pull out a pin from one of the unused slots in the new harness to place where the steering wheel wire is. The harnesses Ive used dont have a pin already there. The steering wheel control unit only uses one wire from the car, and they always neglect to put that on in![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Or you can just use a vampire clip to connect to it, your call
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#60
Or you can just use a vampire clip to connect to it, your call![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#61
Soldering is recommended for the best connection.
#62
the harness u buy connects to the factory harness so you are not soldering wires from the main harness of the car... the metra harness u buy clips on to the factory harness. the metra harness is the one u must solder to the harness that comes with you new deck.... this way u can work outsie ur car and not in the center console.
civic what i am still not certain on tho is.. when it's wired up through the harness... is everything going to work out with my speakers, without that line output thing.. cause there has been some conflicting info on that...
also u kinda lost me with the steering wheel adapter and how to wire it up. thought u meant.. pull out one of the connections in the metra harness that is not used but where and how to hook it up i am lost
#63
Basically, the Metra harness doesnt have a pin for the steering wheel controls. Its just an empty slot on their harness.
What the Metra harness does have is two flying leads for antenna/amp turn on. I took the one I wasnt using out of that slot and moved it to the slot where the steering wheel control is. I may have a pic of it somewhere.
#65
k so i bought the kenwood ddx 419..
trying to hook up the harnesses together along with the SWI-Jack and i'm kinda LOST
its not clear where to put the wires on the swi-jack.. i got the black and red obviously but there is blue, yellow, white, orange, and green which i dunno where they GO..
i wanted to install tyhis tomorrow morning but i dunno if i will have my answer so i am not going to proceed any furthers...
help needed gentleman
#66
Hell I think setting up the SWI Jack is easier without the METRA Harness but then again cutting the OEM isnt a clean Install (I used alot of Tap Splices) what I do recall is that there is 1 remote green maybe? I
think it would be easier just to buy a wire tap splice and installing Before the Metra Harness to Avoid Soldering...
Wire Tap Splice (Sold @ Autozone for Dirt Cheap)
![](http://home.comcast.net/~jrburch_h/jeep/jk/wire_tap.jpg)
And NICEE! the DDX 419 its the newer version of my DDX514 I think they upgraded the Pre-Amp (To 4V) and Changed the Interface get the iPhone Cable ASAP!!
Heres an Old Pic of my DDX514 just installed:
![](http://i882.photobucket.com/albums/ac29/Skirmich/DSC05901.jpg)
#67
OK let me rember a little...
Theres 2 Cables going out ot the SWI Jack that are obvious Leads
(+ and -) BLACK for Ground, 1 RED for +12 (You can use the ACC fuse with an Add-A-Ciruit fuser)
1.- The ones you said "blue, yellow, white, orange, and Green" are for the Steering Remote wire Locate the Steering remote Pin, it must be the A3 use this pic as a reference:
![](http://i882.photobucket.com/albums/ac29/Skirmich/RadioRemote.jpg)
Use the GREEN cable on the SWI JACK for the Steering remote!
2.- There must be 1 Blue/Yellow Cable coming out of the SWI Jack thats the Remote return to the HU! You must locate the Remote cable on your kenwood HU!
3.- Now Locate the Kenwood Pin on your KENWOOD HARNESS! guided by my Installation Manual of my DDX514 it must be the Light Blue/Yellow.:
![](http://i882.photobucket.com/albums/ac29/Skirmich/KENWOODREMOTE.jpg)
With that only you have to Program the SWI JACK but that must be the easiest part!!
Hope this info Helps you Out!
chunkydaddy (10-01-2013)
#68
just re-read the instructions and it said i only need to use the white in pin 3.. and then the red + and the black - ...
then the blue/yellow i got as well, forgot to mention that... i'm surprised tho i only need one wire.. the white. (which was listed in the other set of instuctions)
if i read it all correctly should be done fine... but who knows really lol... will find out tomorrow tho... thanks for the quick reply
#69
2 wires are not connected that come from the kenwood deck.. one is the orange/whitestripe wire that labeled DIMMER, this is because orange/white striped wire on the kenwood harness is labled as ILLUMINATION so is the SOLID orange on the metra harness... therfore i now have the orange/white wire on the metra harness LABELED dimmer just sitting there... WHERE DOES IT HOOK UP
also the MUTE brown wire on the kenwood harness is not hooked up.. where doees that get hooked up to??
much appreciated guys
#70
OK the Orange is for Dimmer what it does is when you turn on your headlight it dimms the screen for 50%...
You need to tap a light that goes on when you turn on your headlights! I used the Central Glove box light just tap the red wire On the light and your done...
CL-S progression 01 (05-21-2012)
#71
I didnt Use the Mute wire, I think its used when you have a button in the steering for it... I just use the ATT button on the Kenwood HU (1 Click into the Volume Dial) for that matter.
#72
I usually left one of the dimmer/illumination wires disconnected. Regardless of which one I connected, when the parking/headlights turned on, the radio would dim.
#73
You use Park Lights/Headlights at night anyway....
The only way of Actually dimming with the Headlights only is to tap the Headlight itself... The Fog Light Switch only gives ground.
#74
Are you saying that connecting it to the stock illumination wire that the radio wont dim because its not tapped into the headlights?
Because if the headlights are on, the parking lights are on. No if, ands or buts.
civicdrivr (05-21-2012)
#78
still didn't program the pac. something isn't going according to plan i may need a resistor it says but first i need to check the voltage on the white wire with it disconnected. mehh
some other time i'll wokr out the bugs it's 30 degrees out i'm not havin it
#80
Resistor for what?
