Does anyone know what fuse to use to hook up remote wire for amp.
Old Aug 22, 2006 | 12:39 PM
digital_04's Avatar
Angry Does anyone know what fuse to use to hook up remote wire for amp.
I tried hooking remote wire up the #5 fuse labled 20 AMP Radio but I am getting a constant signal. This is in a 04" TSX
PLEASE HELP!!!!
Old Aug 22, 2006 | 02:19 PM
KaMLuNg's Avatar
do you have a meter??? that would be the best way to test... i usually go for the radio fuse...
Old Aug 22, 2006 | 02:45 PM
digital_04's Avatar
I did go to that one but still get a constant. I will use my meter later on today and see which one. I don't fill like running wire all the way to armrest. I might not have a choice though
Old Aug 22, 2006 | 03:43 PM
t0ast's Avatar
2Poor 2Furious
That radio fuse you're tapping is probably the switched 12V that turns ont he radio.
Does your TSX OEM (I assume) stereo have an external amp for the stock speakers/sub? If so, then from there, you can find the remote turn on wire (I think usually blue wire?) at the amp for the speakers/sub, and use that to power your amp. That way you don't have to tear up your center console, and you'd only have to run a wire from whereever your stock amp is.
Otherwise, you could always just put a switch inline from the radio fuse to your amp so you can switch on your amp manually - ghetto but it works.
Old Aug 22, 2006 | 06:10 PM
Osamu's Avatar
i've never used the fuse box for a remote in an acura, but in most cars i usually go for the ACC fuse. This should turn your amps on in the ACC mode on the ignition. I think acuras should have a similar fuse, i know i've used it in various toyotas. You probably wouldn't be able to turn off your amps by turning off the radio, but most people i know never even turn off their radios anyways.
Old Sep 1, 2006 | 11:02 AM
elduderino's Avatar
VP Electricity
All TSX's have a remote turn out out of the radio.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
