do i need a cap ?
Old Jul 20, 2004 | 07:57 PM
MaCe's Avatar
fellow MASShole
do i need a cap ?
im gunna be running 2 eclipse amps 1 is 85x 4 the other is 370 x 2 at 4 ohms
i have an optima red top now think the stock alt will be able to keep up ? i dont want to have dimming
MaCe
Old Jul 20, 2004 | 08:01 PM
BEETROOT's Avatar
Yeehaw
what are you running the 370 x 2 into?
Old Jul 20, 2004 | 08:26 PM
proaudio22's Avatar
-S namyaC-
Cap = for adding to an already working system to tighten up the bass. Will not fix anything as far as dimming. With a long current draw (more than 10ms) the cap will discharge down to the car's running voltage. Caps are for VERY short, high current draws.
Extra Battery = for playing the system with the car off. It won't do dick with the car on unless the voltage is less than 12.5v - and if that is happening - some shit is really fucked up.
Larger alternator = real fix. You can't pull power out of your ass.
Your current draw with class AB amps is about 40-50 amps continuous (I assume they are all AB b/c I don't know of any car class Ds that are dual channel). This is probably around The stock alternator can really only handle an extra 25-30 amps. You'll just have to see how it does.
Old Jul 21, 2004 | 01:50 AM
MaCe's Avatar
fellow MASShole
subs are jl audio 12 w6's the 85 watts are goin to boston components and 6x9's
so proaudio what u sayin ? that i might have get a bigger alt?
vpasla1
Sep 17, 2016 07:24 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
jmaxima03
Sep 27, 2015 10:22 AM
