Custom TSX trunk
Old Apr 3, 2006 | 09:13 PM
TSX.Fury's Avatar
send me a link to JDM??
Custom TSX trunk
Ok guys, go easy on me... this was my first try at building or painting anything custom. I painted my JL amp and sub and built the box. For the paint job I put down a white, then a J and L I made from a vinyl sticker I had, then painted everything black, then took up the vinyl and put down a light coat of gray metallic.
The box I built because I wanted something different and wanted to still have use of at least half my trunk
Old Apr 3, 2006 | 09:55 PM
Jonesi's Avatar
Defintley different and unique. It just looks like uhhh half.. It could probably grow on me.. Any pictures from the other angle?
All in all not a bad first attempt at all.. I usually go through about 10-15 revisions before I get something I like.
Old Apr 3, 2006 | 10:33 PM
NYZGREATST's Avatar
Sig Rho's Finest
thats a huggeee box!!! did the sub need the volume?!
Old Apr 4, 2006 | 12:11 AM
TSX.Fury's Avatar
But because I wanted to have it only take up half the trunk, I needed to extend it out so I could get enough surface area to mount both the amp and the sub.
Old Apr 4, 2006 | 12:33 AM
cM3go's Avatar
odd shape
Old Apr 4, 2006 | 03:45 AM
boku's Avatar
Scru U guyz, Im Goin Home
i'm guessing that the box takes up only a small portion of that b. board....?
Old Apr 4, 2006 | 11:30 AM
CJams's Avatar
Guinea Pig
Good job for your first time. Looks clean. The shape is a little odd but it looks clean, no wires, and you can still fit about 4-5 bags of food and a gallon o'milk.
Old Apr 4, 2006 | 11:41 AM
PixelHarmony's Avatar
Master Graphic Artist
Isn't it not good for the sound if you build a sealed box without the correct amount of volume?
Man... I wanted to build my own box as well but since I'm still moving around in college I need all the trunk space I can get.
Good job on your first build
BoricuaTL
Apr 8, 2016 01:08 PM
mugen_kid
Nov 13, 2015 10:38 PM
handsom-hustla
Nov 13, 2015 05:04 PM
VA2000TL
Oct 2, 2015 08:26 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
