correct code
Old Sep 4, 2006 | 10:50 PM
acura dude's Avatar
8th Gear
correct code
need help from the experts.. mechanic disconnected battery to do a repair. After connecting battery back the radio does not want to take the CODE. This is the right code. Did some repairs before and allways worked fine. Thanks in advance. acura dude
Old Sep 7, 2006 | 09:02 PM
CAB NEWYORK's Avatar
had same problem for the 2g tl unplug the radio antenna from the back its on the driver side
Old Sep 8, 2006 | 10:56 PM
supersnakeking's Avatar
5th Gear
According the manual, if you have tried certan fail attempts, you need to leave it on for at least 1 hr before you can re-enter the correct code and get run properly again.
Old Sep 9, 2006 | 01:25 AM
acura dude's Avatar
8th Gear
I have tried an hour, two a day, remove the battery cable, put it back, enter the code slow and fast, press soft and hard. I ran out of ideas.
Thanks. acura dude
Old Sep 9, 2006 | 01:28 AM
acura dude's Avatar
8th Gear
my next experiment will be what newyork cab sugested,remove the radio antenna from the trunk, I think.
Old Sep 9, 2006 | 02:57 PM
Ptown_tsXXX's Avatar
same thing happend to me when getting my car fix. I found a sticker with the code on the side when you open up the glove department. See if they stuck one there for you.
Old Sep 10, 2006 | 05:14 PM
csmeance's Avatar
on the mdx's you can type in 0000 as the radio code and it would accept it.
Old Sep 11, 2006 | 06:45 PM
acura dude's Avatar
8th Gear
I will try the 0000 code.
Thanks everybody for the help.I sure can use lots of it.
acura dude
Jamus22
Jun 11, 2023 10:08 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
