Compustar Alarm
Old Jun 28, 2002 | 05:22 PM
Hornda's Avatar
Compustar Alarm
neone have a compustar alarm with auto start??? And if yes does it start the AC when you use autostart?
Old Jun 28, 2002 | 05:24 PM
StanMan's Avatar
i think it's similar to most remote start systems that is in the market...you must have either the AC or heater turned on before you exit the car. but that would be trick being able to control it from the remote!
Old Jun 28, 2002 | 06:18 PM
Hornda's Avatar
i have a friend that has the compustar alarm and his ac dont turn on when he uses auto start... same with my other friend...
Old Jul 1, 2002 | 01:45 PM
acur8ly's Avatar
I have the alarm on both of my cars and you either have to leave the ac on or have your installer hook it up as one of the optional functions, you probably can only turn it on using one of your options
Old Jul 1, 2002 | 04:39 PM
Hornda's Avatar
on my friends car... he leaves the ac on and when he uses autostart it doesnt start... im pretty sure most other auto start would start the ac but my friends doesnt... that is why i am asking about people with compustar alarm systems... i dont care about the others
Old Jul 1, 2002 | 05:05 PM
acur8ly's Avatar
well your answer is yes, it works that way. Which compustar are u interested in?
Old Jul 2, 2002 | 02:35 PM
2007AcuraRL's Avatar
Just leave the AC (or the heater as the case may be) set to on before shutting the car off. The only thing that doesnt work this way is the rear defroster, since its relay resets itself to off when you shut off the car. To get this to work, you'd have to wire up a separate relay to activate the switch, and then use one of the spare channels on the remote. You'd have to remote start the car, wait a second for it to start, and then remember to press the second channel on the remote to turn on the defroster.
Old Jul 2, 2002 | 09:27 PM
acur8ly's Avatar
2002tl which model of the alarm do u have. I have the 2wfm-as om my cls. Was reading that u can upgrade to the Spread spectrum. I want to do this, wondering if anyone else has?
Old Jul 2, 2002 | 10:27 PM
Beason's Avatar
Didnt know if you did a search and found this, but here ya go, this may answer somethings......
http://www.acura-tl.com/forum/showth...threadid=42061
Old Jul 3, 2002 | 12:22 AM
Hornda's Avatar
dood... i already done told u.... my friend leave his ac on when he shuts off his car... but the ac will not start when he uses his auto start option on his COMPUSTAR alarm... I already know that clifford would start your AC and many other alarms... But I am asking for those who have compustar alarms... if you dont have one please dont reply cuz u dont know what i am talkin about... U might think i am being dumb and being an a$$ but i have a friend that went thru 3 compustar on 3 different cars and i have another friend that has a compustar alarm and none of them starts the ac when using the autostart EVEN when the AC is left on
Old Jul 3, 2002 | 12:34 AM
StreetEffectz's Avatar
the only reason that an alarm of ANY KIND would not start the AC is because the installer didn't connect the correct accessory wires
Old Jul 3, 2002 | 02:21 AM
Hornda's Avatar
so are u telling me that out of all the 4 cars that has the compustar that i know of... doesnt start the ac is cuz the installer dont know how to ??? but when he installs other systems like the viper it actually works? all i am asking is for those who has compustar alarm system.... does ur ac work when u use autostart.... and if u dont have a compustar alarm please dont reply cuz i am assuming that u have not ran into a compustar yet...
Old Jul 3, 2002 | 07:00 AM
acur8ly's Avatar
Your ac will work, I have the experience of having it on 2 cars that it worked on
Old Jul 3, 2002 | 07:34 AM
Yes, compustar WILL work your AC.....there are outputs from the alarm that need to be hooked up to your accessory wire that runs the AC.
OH, and I know this because I am an installer
Old Jul 3, 2002 | 08:04 AM
pianoman41's Avatar
If Ron (StreetEffectz) is telling you something about an alarm, listen up because it is going to be good, free advice from a very competent installer in the NJ area.
Old Jul 3, 2002 | 08:07 AM
Believe me, Steeteffectz knows his install stuff. And since I have a the Compustar alarm and I was an installer for 12 years myself, I can assure you it was a bad install (improperly wired) that is to blame. My car gets plenty cold and refreshing from my Compustar remote starter before I get into it. As i indicated in my earlier post, the only thing that wont work without some modding is the rear defroster.
Old Jul 3, 2002 | 08:29 AM
pianoman41's Avatar
And this is because of the car's design--not the alarm. My Clifford is the same way. My front defroster and A/C will work fine with my remote start but the rear defroster defaults to the off position. Even with New England winters this isn't too much of a problem. The car is usually warm enough on the inside by the time I get in that it takes a short amount of time to defrost the window once I press the switch.
Old Jul 3, 2002 | 10:52 AM
Hornda's Avatar
ok thanks... i guess now i gotta find an installer that knows how to install those alarms in houston
Old Jul 3, 2002 | 01:26 PM
Pianoman, one of these days i am going to pull apart the dash cluster again and come up with a fix which will send a delayed ground pulse (maybe a delay of 15 seconds) via a relay to throw the defroster on after the car has started.
Old Jul 3, 2002 | 01:35 PM
pianoman41's Avatar
Cool. If you do and it works let me know what you did. I'd be interested in this set-up myself.
Jul 16, 2017 07:33 AM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
njresendez
Sep 21, 2015 11:23 AM
