Components
Old Jan 3, 2005 | 12:35 AM
yunginTL's Avatar
trill recognize trill
Components
What is really the best pair of components to run sum serious bang wit? I'm leanin towards DA
Old Jan 3, 2005 | 07:23 AM
dnd2984's Avatar
I love Diamond Audios, but I personally love the Alpine SPX even more. I have the SPX in my front and rear doors with a 300/4 and they are clean and get extremly loud.
Old Jan 3, 2005 | 08:26 AM
Scott P's Avatar
Mobile Elec. Guru
I've tried just about everything you can imagine: Diamond, Alpine Type X & Type R, Pioneer Rev Series, MB Quart QSD and PCE series, Phoenix Gold, Memphis SQ series, Boston Pro, and so on. Depending on the power you are going to throw at them, so far the ones that i have liked the best as far as having great midbass and an aggressive, yet not harsh or bright tweeter have been the orion p6 components. Word to the wise though, be prepared to do a fair amount of work if you are installing these yourself. the woofer and the crossover are huge.
Old Jan 3, 2005 | 08:41 AM
Hawhyen51's Avatar
There are several posts on this topic. Try this link for some info ..... Use the search feature or check this Forum.
Old Jan 3, 2005 | 12:34 PM
AcuraX2's Avatar
There are a lot of really good brands. The "best brand" is probably a tough question. Peoples tastes are different and what one person may love, anther may hate and vice versa. It would be best to listen for yourself. If you can not do that, go with a top brand name that fits your budget, have it properly installed and it should fit the bill nicely.
For what it is worth, to my ears, I love my Diamond Audio M661 and I have not heard anything I like better.
Old Jan 3, 2005 | 12:53 PM
LIGHTBEING's Avatar
Dynaudio is serious.
Old Jan 3, 2005 | 03:57 PM
yunginTL's Avatar
I read that thread and I am considering going with the Diamond m661, is the install a DYI? What about gettin the tweeter in and are there any fitment problems? Thanks for your help
Old Jan 3, 2005 | 05:02 PM
shawhite's Avatar
if you are going to go with the m6 series spend the extra bucks and get the hex... world of difference..
Old Jan 3, 2005 | 07:08 PM
DerrickM's Avatar
M661's go in easily--both mids and tweeters (into 2001 TL). Use 3/4" spacer for mids. Crossovers are the difficult part. I took mine out of the boxes and mounted them right to the door in the one place they would fit. The other option is running two sets of wires and hiding the crossovers somewhere else.
The DA instructions say to test tweeter placement before cutting. I didn't do that and ended up having to switch to silk tweeters because the metal domes were too bright for me where I mounted them. I'd take their advice and tape the tweets to the door and listen to it for a day or two before mounting the tweeters..
Old Jan 3, 2005 | 07:25 PM
yunginTL's Avatar
where did you have em mounted
Old Jan 3, 2005 | 10:31 PM
DerrickM's Avatar
I mounted them myself. I have pictures on a recent thread called "Diamond Audio Rocks".
Old Jan 3, 2005 | 11:45 PM
yunginTL's Avatar
how u cut out the hole for tht tweeter?
yunginTL's Avatar
Old Jan 4, 2005 | 09:34 AM
Hawhyen51's Avatar
Here's the link to DerrickM's post DA Rocks
Old Jan 4, 2005 | 01:28 PM
brianlin87's Avatar
ASM I.S. Design FTW.
dynaudio > diamond audio
Old Jan 4, 2005 | 07:57 PM
DerrickM's Avatar
I traced circles on the inside vinyl, then cut the vinyl with a razor knife. Then I drilled holes around the inside of the circle through the plastic, and cut that out with sidecutters. From there I used the knife to carefully trim the hole to be perfectly round.
Easier would have been a hole saw for a drill, but I didn't have one the right size, and it would have taken longer to go buy one than to just do it the manual way.
But, remember what I said about tweeter placement. The best place seems to be the top front of the doors forward of the release levers.
If you're going DA I'd go up to the Hex (S) series and get the silk tweeters.
Old Jan 4, 2005 | 09:35 PM
Jput's Avatar
Is anyone here familliar with OZ audio? I personally would put the OZ matrix series components above the Focal or Diamond audio components any day.
Old Jan 4, 2005 | 10:37 PM
yunginTL's Avatar
which model # wurks and how much would it run and whats the diff?
Old Jan 4, 2005 | 11:21 PM
DerrickM's Avatar
I wasn't very clear on my last post: When I said "remember what I said about tweeter placement" I meant that you should test it for what sounds best. Then I went on to say that the best place was forward/high--I meant that's the EASIEST place, not necessarily the best-sounding place. Sorry.
One of the reasons I chose Diamond was the shallow mounting depth. You'd need to double-check, but I think the Hex series 6.5" comps also have the same 2.125" depth.
As for the difference, I haven't heard the Hex's, so I couldn't say. I do know now that I prefer soft-dome tweeters to metal-dome, and that the Hex's can be purchased in either variation.
I'd go to a couple of stereo shops and see what sounds best to you before making your final decision.
Old Jan 5, 2005 | 12:57 AM
OntarioTL's Avatar
I agree with all that say it is personal preference. I have Alpine Type-R (5/14") components in the front. None are installed in the rear as with the set up I dont need rears (dont want to screw up the soundstage). They sound nice on their own.
With that in mind though, I have ordered the Alpine Type-X set to try them out. Hope I wont be disappointed.
OntarioTL
Old Jan 5, 2005 | 10:03 AM
fpique's Avatar
NorCal you Beezy!
OZ are cool... personally I like Alpine... I say go to a serious car audio dealer and play with his shet...
Old Jan 5, 2005 | 10:37 AM
yunginTL's Avatar
any1 no any good places in htown?
Old Jan 11, 2005 | 09:29 PM
yunginTL's Avatar
The M series or HEx Series Diamond components? And also whats the difference quality and pricewise
Old Jan 11, 2005 | 09:42 PM
bimmer88's Avatar
Boston Pro's sound great...
Old Jan 13, 2005 | 11:21 PM
DerrickM's Avatar
I think the Hex series cost around 50% more than the M series. I don't care for metal dome tweeters, so I would go for the Hex series. (You can buy the hex series with either metal or silk--go for the silk unless you don't play it very loud).
The metal domes have an absolutely INCREDIBLE detail, but are quite harsh at high volumes. Diamond was kind enough to send me some silk replacements, and I'm very happy with them. While not as detailed, they're kinder on the ears at high volumes inside a car.
Old Jan 13, 2005 | 11:28 PM
yunginTL's Avatar
damn 50% more??
Old Jan 14, 2005 | 07:47 AM
DerrickM's Avatar
I think they're $300 on eBay brand new. Well worth it.
Old Jan 14, 2005 | 02:48 PM
NSXNEXT's Avatar
Rainbow CS360.30
Old Jan 14, 2005 | 03:19 PM
AcuraX2's Avatar
Originally Posted by NSXNEXT
Rainbow CS360.30
drooolll!!!!
Old Jan 14, 2005 | 07:17 PM
NSXNEXT's Avatar
Originally Posted by AcuraX2
drooolll!!!!
The case that those things come in is probably worth more than most component sets.
On a serious note, I went with the CDT HD63s. They are amazing. Low wattage requirements and they pound the midrange.
Old Jan 15, 2005 | 01:02 AM
vishnus11's Avatar
heard quite a bit about cdt. Those suckers look huge. Where exactly did you mount woofer, midbass, and tweeter, on your door for optimal imaging. How do you like the sound quality.
Old Jan 15, 2005 | 06:28 PM
yunginTL's Avatar
DIAMOND AUDIO S600s HEX 6.5" COMPONENTS is what im gonna go with. Best pricee i got is $340 any1 got a better price?
4drviper
Apr 23, 2025 07:13 PM
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
