Changing a Navi Screen
Old Jan 31, 2003 | 02:19 PM
Brucepancake's Avatar
Question Changing a Navi Screen
I am getting ready to change the screen in my 99 TL . it is worn down. Does anyone know how to take off the dash board? I am also wondering , is all I have to do is plug the new one in, and will only a 99 do or could I use a 2000 screen. I want to do this myself not only for the education factore but I would like to save some money.
Old Jan 31, 2003 | 03:42 PM
ArN 2000 TL's Avatar
Moderator Alumnus
Should be fairly easy...to do so you have to remove the trim pieces around the navigation unit...no need to remove the whole dash...
Old Jan 31, 2003 | 05:07 PM
shawhite's Avatar
is your unit defective or you just want to replace it... this sound like something you could have covered under warranty if it was defective but if you really want to do it yourself here ya go... simply remove the stearing column by removing the 3 screws on the bottom (there might only be 2 i dont remember off hand)... now remove the 2 screws on the top of the meter assymbly... then using your figure tips pull outward on the dash peice (i would start on the side towards the navi screen and work my way to the gauge side).... the peice should pop right out.... and then after you get this plastic peice out of the way the navi screen will be held on with 4 screws ( i think for maybe only 2 but you get the point)... and the navi screen should just plug in... unplug the old one plug in the new one... reattach everything and there you go...
Old Feb 7, 2003 | 02:19 PM
I just want to replace it . It has alot of scratches on it. I am also having a hard time finding one, if anybody has any ideas let me know!
Old Feb 7, 2003 | 08:44 PM
shawhite's Avatar
here check this place out...
http://www.acuraautomotiveparts.net/...p/mws/home.htm
Aleax
Sep 11, 2015 11:31 AM
Gianni Formica
Sep 7, 2015 08:28 PM
yahelou
Sep 6, 2015 09:12 PM
Rexorg
3G MDX (2014-2020)
Sep 3, 2015 12:40 PM
SUPRMN84
Sep 2, 2015 11:50 PM
