changing to aftermarket deck in tl
i was wondering does anyone know if we have to change all our speakers out if we decide to change out the bose deck. A guy at circuit city told meeh that if a get a aftermarket dect that i would have to get all new speakers because the bose will not work with any other deck besides bose>
you will not need an adapter, and the amp isn't on the speakers. The bose system in the tl (atleast as Ihave seen on the 99-00 TL's) have a stand alone amp running a 4 ohm load to the speakers. If you put in an aftermarket deck you will need only the standard 98+ honda accord harness and the Metra 99-7868 dash kit. You will lose the use of your stock subwoofer though.
Originally posted by blk_tl
Yeah, you'll lose the sub and also from the one i heard it sounded like garbage
I agree with Scott. I first just changed the head unit and it did make a noticable difference. Not huge but, noticable. I am not sure if you would even notice that the factory "sub" is not working.
9th Gear
Was there an option in 99 for a premium sound system that included tweeters or was teh sound the same for all options? I'd like to add some components to my front and rear doors, but don't like the tweeters just hanging out. I like the sleeper look.
BTW, my first post (just got my 99 TL (non-Navi) on Sat, been reading since then)!
Originally posted by oVerBoost
what about aftermarket deck and aftermarket sub but stock speakers? What would you need to do that?
You would need the aftermarket deck, a Metra install kit, unless you want a custom install, a sub and an amp for the sub. Plus of course, all the wiring that would be involved. It can be done without much trouble. I would seriously consider changing the stock speakers, if you are going to all the trouble of changing the head and adding an amp and sub.
I think i remember reading somewhere on here that the bose system operates on a four ohm load, which as far as I know means you would be able to put in speakers without an amp bypass. I don't know any of this for sure since I haven't tested to resistance of the factory speakers myself, nor have I tried doing a straight swap like that. Knowing bLose though, it's a relatively safe bet that it won't work without a bypass. . .
basically a bypass of the amp would allow you to essentially reset the resistance to four ohms (its actually a little more detailed than that depending on the head unit used and what not), but in this case i believe it is irrelevant to go into that much detail. as far as the factory eq goes, i forgot about that. It is built into the factory radio and i think you would have to do something akin to the DX6 project to bypass it so that you could fully utilze the full potential of the new speakers...
Originally posted by TLProspect
Are the bypass and mods to the Bose EQ settings complicated and if so, could I just trust Cartoys or another shop to install the speakers and make the necessary adjustments?
What would be your best suggestion for me then as far as upgrading my speakers? I am not an electrical know-it-all by any means, and am probably not even a novice... I don't want to be stuck with Blose any longer than I have to but I want the upgrade to be worth it and sound better and clearer- though I prefer not to have to buy a bunch of extra equipment like a new amp, etc although I am not sure what to do about the Bose sound EQ....
trinikidcl
Sep 4, 2015 12:56 AM
