Cd changer installation locations
Old Jun 17, 2003 | 03:29 PM
Diesel_Blue_TL's Avatar
Well I finally got a cd changer :smokin: Now where can I install it? Will it fit under the front seat? if so what do you bolt it to? trunk , ahhh , glovebox? armrest?
thanks
Old Jun 17, 2003 | 03:35 PM
ArN 2000 TL's Avatar
Moderator Alumnus
why not put it in the trunk where the factory one goes?
Old Jun 17, 2003 | 04:28 PM
NSXNEXT's Avatar
I put mine here....
Covered it up with some gray carpeting....Stealth
Old Jun 17, 2003 | 07:00 PM
AcuraX2's Avatar
I put mine in the left rear corner of the trunk. I took out the plastic storage tray and was able to bolt the changer right to the metal. I mounted it vertically and it takes up no room. I like the factory spot but, I did not have room after my box.
Old Jun 17, 2003 | 10:13 PM
2_tl_owner's Avatar
I put mine under the front passenger seat facing the back. This makes it easier to get CD's in and out of without having to get out of the car.
It can be a problem sometimes with people sitting in the back seat, but if you put if far enough under the seat, you can minimize the problem.
Old Jun 18, 2003 | 01:09 PM
FTM-1's Avatar
Well mine is in the factory CD changer spot because its the factory CD changer. It also came with the rail that keeps it from getting bumped.
Old Jun 19, 2003 | 09:06 AM
VTEC11's Avatar
FTM,
what rail are you talking about? You can't mount it in the factory spot without it? Can you buy that rail separtley?
I am gonna install a honda changer out of a 2000 accord into my 2000TL. i installed it in to accord into the armrest counsel, becausei had the counsel mount kit.. but that won't work on a TL i'm pretty sure.
SO i wanna put it in the factory spot in the trunk... Does anyone know what parts i'll need? i have the changed and the cable, with the square end..
thanks !
Old Jun 19, 2003 | 05:13 PM
FTM-1's Avatar
Post
Originally posted by vtec11
FTM,
thanks !
The little rail or bar is mounted to the floor next to the changer. It just keeps stuff in the trunk from hitting the changer. It most be a part of a kit because its in my car. When I got my car new I had ordered the factory changer & this is how the dealer had it mounted. You would not need the bar to mount the changer. Its got to be a kit that you can get but not needed if your trunk is not loaded with stuff. I guess it would protect the changer if something would slide into it while making turns or braking.
Old Jun 19, 2003 | 09:52 PM
VTEC11's Avatar
okay, but how is the changer actually secured to floor in the trunk? is it bolted down??
i guess i'll try to remove that plastic cover and have a look see. Can you tell me if yours is bolted down, or if there's a slot or something where it drops into..
thanks...
Old Jun 23, 2003 | 09:02 PM
Talking
ya.. The A-Spec doesn't have that problem.. The loader is built into the radio in the console..... :p
but all the other places the guys had mentioned... are perfect too...! but ya.. the under the passenger seat it very cool.. you can change magazines while driving..
Old Jun 24, 2003 | 05:15 PM
VTEC11's Avatar
hey man,.. somebody answer my question...
Old Jun 24, 2003 | 07:59 PM
NSXNEXT's Avatar
vetc11,
The mounting bracket that has the bar to keep it from getting hit in the trunk holds it down securely.
I have one for sale if you're interested. If you're close to me in Mt Laurel, I'll even install it for free.
PM me if you're interested.
Neil
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
spoiler900
May 25, 2016 10:16 PM
Sep 17, 2015 10:09 AM
asahrts
Sep 4, 2015 05:55 PM
