Cd changer installation locations
Well I finally got a cd changer :smokin: Now where can I install it? Will it fit under the front seat? if so what do you bolt it to? trunk , ahhh , glovebox? armrest?
thanks
thanks
I put mine in the left rear corner of the trunk. I took out the plastic storage tray and was able to bolt the changer right to the metal. I mounted it vertically and it takes up no room. I like the factory spot but, I did not have room after my box.
I put mine under the front passenger seat facing the back. This makes it easier to get CD's in and out of without having to get out of the car.
It can be a problem sometimes with people sitting in the back seat, but if you put if far enough under the seat, you can minimize the problem.
FTM,
what rail are you talking about? You can't mount it in the factory spot without it? Can you buy that rail separtley?
I am gonna install a honda changer out of a 2000 accord into my 2000TL. i installed it in to accord into the armrest counsel, becausei had the counsel mount kit.. but that won't work on a TL i'm pretty sure.
SO i wanna put it in the factory spot in the trunk... Does anyone know what parts i'll need? i have the changed and the cable, with the square end..
thanks !
thanks !
Originally posted by vtec11
FTM,
thanks !
FTM,
thanks !
okay, but how is the changer actually secured to floor in the trunk? is it bolted down??
i guess i'll try to remove that plastic cover and have a look see. Can you tell me if yours is bolted down, or if there's a slot or something where it drops into..
thanks...
thanks...
ya.. The A-Spec doesn't have that problem..
The loader is built into the radio in the console..... :p
but all the other places the guys had mentioned... are perfect too...! but ya.. the under the passenger seat it very cool.. you can change magazines while driving..
The loader is built into the radio in the console..... :p but all the other places the guys had mentioned... are perfect too...! but ya.. the under the passenger seat it very cool.. you can change magazines while driving..
vetc11,
The mounting bracket that has the bar to keep it from getting hit in the trunk holds it down securely.
I have one for sale if you're interested. If you're close to me in Mt Laurel, I'll even install it for free.
PM me if you're interested.
Neil
Neil
TLDude876
Dec 28, 2016 03:18 PM
asahrts
Sep 4, 2015 05:55 PM
