Car stereo prob. - 03tls
Old Dec 12, 2008 | 05:02 PM
Angel03TLs's Avatar
HELLO TO ALL
When i went to eject a cd (number 1 out of 6) the cd stereo didn't complete the ejecting function. It stopped with the cd still inside, the flap semi-open(half way)and displayed an error 1 message. I was able to take out the cd through the small gap and i though that would solve my problem but no luck. I am not able to change any of the other 5 cds still in there. Pretty much all the cds i use or burned. I checked with the local Acura dealer but the solution they offered runs me above $400 and 4 to 6 weeks with out a stereo. Any feedback/solution/suggestions will be greatly appreciated.
THANKS
Old Dec 28, 2008 | 07:08 PM
MOBB's Avatar
To get the stuck CD out try smacking the side of the unit HARD and repeatedly the motor will eventually skip and throw the CD out.
Old Dec 30, 2008 | 08:52 AM
markgrut's Avatar
I had/have the same exact problem. I saw a thread on here somewhere and someone listed illustrated instructions on how to take out the stereo. That's what I ended up doing. It looks a little daunting, but if you follow the instructions, it's pretty easy. After taking out the stereo, I had to sort of fidget with the stereo and slide the CDs out. I can't say the CDs didn't suffer - I'm pretty sure they're scratched on the edges where I used tweezers to pull them out of the stereo. My stereo worked fine for about two months, then the same thing happened. I think I just need to buy a new stereo.
btw, the instructions I found were posted by someone installing something called an Ice Link mp3 connector to the back of his '03 TL stereo. If you look around, you'll probably find the instructions. The only tools I needed were a couple of screwdrivers.
Old Dec 30, 2008 | 08:55 PM
gold2003tl (90)'s Avatar
2003 TL-p
dealer aint going to help u at all. they will "fix" it for 400 bucks. burned CD thing is not true if they tell u thats why it brook.
rip out the old one and go to Crutchfield for all the parts.
you need a face plate adpater and any signal din will fit. wire it up with the metra harness to the 4 door speakers and wire up the sub in with this thread https://acurazine.com/forums/show...1&postcount=90
i went with a kendwood - there are no cd player that just slip right in with out the face plate.
please search this has been covered many times and is a very very common problem
if u get the Bose fixed you will still aways have problems with it. it will never stop jamming. there a many dyi's on how to take it apart and put it back together. its not hard to do and will save u a lot of money.
this is what i did
this is what mine looks like - i still have the stock speakers which sound ok. they sound better with a new head unit.
Old Jan 8, 2009 | 04:25 PM
Angel03TLs's Avatar
sorry for the late response...but i was able to get the cd out so that wasn't the problem
Old Jan 8, 2009 | 04:26 PM
Angel03TLs's Avatar
ok thanks for the feedback
Old Jan 8, 2009 | 04:29 PM
Angel03TLs's Avatar
thanks yea that's what i'm thinking of doing...but i'm thinking of getting a double din... i talked to a local shop and they said that it would fix...but ill see what happens thankz
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
iesu3423
Sep 29, 2015 08:04 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
