TL: Can't read burn cds!
Old 03-16-2010 | 04:08 PM
ballersonly's Avatar
my cd player won't read burn CDs!! why and what can i do?
2000 TL 3.2
140k
Old 03-17-2010 | 01:07 AM
delheat's Avatar
get a 02-03 6 disc changer or a ipod adapter
Old 03-18-2010 | 01:09 PM
RK69's Avatar
6th Gear
Are they burned as mp3s? If so try to burn them in as an Audio CD (if using iTunes). Can the CD play on a home CD player that does not play mp3s? If it does you migh try a different manufacturer of blank CDs. Sony or Phillips should be fine.
Old 03-18-2010 | 01:46 PM
myisanog's Avatar
that happened in my homies legend, i burned the cd on the fastest speed and it doesnt play. he told me to burn it on the slowest and all of a sudden... we were cruising again
Old 03-20-2010 | 04:43 PM
Bob_F's Avatar
the single disc CD player that came with the 1999-2001 TL is notorious for having problems with burned CDs. There are unit to unit variations so changing the burning strategy or the type of blank CD-R will not always be a solution.
As delheat mentioned, you can install a headunit from a 02-03 TL or you can install an iPod adapter. I installed both of those in my 1999 TL. And third option is to install an aftermarket head unit.
Old 03-28-2010 | 08:39 AM
coffeefingers's Avatar
I will not use burned cds in my 2002 TL-s again. Too many problems with them jamming and being a pain to eject. One time a burned cd would not eject...even with me poking at it with a small screw driver. I didn't want to make the situation worse so I took it to the dealer and he took apart my radio unit and got the cd out...without damaging the unit...even though he said he couldn't guarantee it. It cost me like $200 but cheaper than buying a new or rebuilt version. Besides I wanted to keep the stock look.
Even the dealer said these units don't work well with burned cds.
So if I want to listen to a burned cd...I play it through a portable cd player and run it through my tape deck with a connector. LOL. Cheesey but it works safely.
Old 04-12-2010 | 07:02 PM
thewhitepearl's Avatar
try burning onto the memorex.. i use the black ones burnt @ 12x. sure it takes a little longer, but i never get the read errors like i did w/cheaper media burnt at high speeds. hts.
MrHeeltoe
20
02-23-2023 01:54 PM
calrow
05-03-2017 10:21 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: TL: Can't read burn cds!
