BOX BUilding Help
Old Sep 23, 2003 | 05:27 PM
Titand19's Avatar
East Coast Boost.!
BOX BUilding Help
Hey guys, I'm lookign to build a box for my 12L72. I want to to be tunned to approx 25-35 hz. does anyone know how to do this?
Old Sep 23, 2003 | 07:48 PM
suXor's Avatar
Still trolling
You don't want your peek around that freq unless you ahve other subs tuned above that.
Good spot is 45-50. WHat is the wattage you are running into it? If it's a lot of power (near the peak power handling), go sealed @ 1.0cuft. You can actually build it as big as 2.0 cuft, without much audible difference. It will be a bit softer at the peak tuned freq, but is smoother across the slope then a smaller box.
If you just want loud, you can build a vented box. It's more difficult to calculate and screw up, but the curvers are heavy!
Anyway, look at this
Old Sep 23, 2003 | 07:54 PM
Titand19's Avatar
East Coast Boost.!
I will be using 2 8" midbass drivers, so taht is why I plan on running this sub at that hz.
I'm running 750 watts to it.
Old Sep 24, 2003 | 05:30 AM
mcdanjw's Avatar
Use this sealed box designer...
http://www.ajdesignsoftware.com/speaker/
If you haven't built a box before, I wouldn't recommend building a vented enclosure. It is way too easy to be a little off and have the box sound like ass.
Old Sep 24, 2003 | 08:51 PM
Titand19's Avatar
East Coast Boost.!
link doesn't work
Old Sep 25, 2003 | 04:23 AM
mcdanjw's Avatar
Try this.... I screwed up. Cut and paste prior link or use this.
LoneRonin
Jan 4, 2016 01:03 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
