Boston Acoustics Pro60's
What are some good amps to power these speakers @ 125watts RMS or close to it at 3 ohms beside the JL amps? or better yet who ever has these speakers what amps are u currently pushing them with? i looked at some ARC and Zapco amps but i couldnt find any amps that were 125x4 and 3ohms..thanks
Team Anthracite Member
Hate to admit this, but I'm currently installing these speakers in my TL and I'm using the JL e4300 to power them. They are going to be way underpowered, but they are only my rear speakers. I'm using the Boston Z6s in front with a JL 300/4 bridged to two channels.
Originally Posted by jpswanberg
the metal dome tweeter is too bright for my ears, and i would try a tube amp (tubedriver 750 or 2150) to tame the edge. jps
outside of jl and some others, i doubt you will find an amp with a 3 ohm rating. if anything, i think the amp will "round up" to 4 ohms for you...or split the difference?? alpine has the mrv-f545 rated at 125Wx4 but may arrive with a birth sheet closer to 150. it's decent and fairly cheap if you got the hook up.
2001 CL Type S
I've heard that the Pro60's are incredibly power hungry and require upwards of 300w each to get the mids moving. You may want to go with a comp set that requires less power to bring out it's full potential.
thanks for everyone's input i decided to go with the Diamond Audio Hex's..the S600A's.....they sounded really good...and yes i got them fron and authorized dealer...6TH Ave.
In my previous car I had Boston Z6's in the front and Boston RM9's (best 6x9's they ever made) in the back (GM car). I was using 2 JL 300/2 amps to power them all. The JL amp powered the Z6's to perfection.
I'd suggest going with a JL 300/2 for the Pro6's as well.
Ponsey_Scheme
10-23-2015 09:16 PM
phatpat
03-26-2003 12:07 PM
icy CL
06-24-2002 03:29 PM
onedayzpay
04-27-2002 07:03 PM
