Bose spec for the 97 CL !!
CL Owner. That's it !!
Hi Hi,
Does anyone happen to have a spec of the factory Bose system for the 97 CL ?? I realize that there's a spec for the 2001 CL, but what about the spec for the first generation ??
Thanks,
E50
3.0CL
Razo shift Knob / Pedals
Eibach springs
17' Momo wheels with 235/40/17 Bridgestone Potenza S02
Thanks,
E50
3.0CL
Eibach springs
Hi Hi,
Do U happen to know where the factory Amp is located in the 97 CL ?? Need to find it to hook up some source.
E50
3.0CL
Eibach springs
E50
3.0CL
Eibach springs
Stage 1 Audi S5
Well i know in my mom's Q45 w/the Bose system each speaker is independently amplified. This means there is no central amp and just a little amp attached to each speaker making upgrading and adding to the system very difficult as we found out. Not sure if this is the same for the CL or not since have a 2.2 which doesnt come w/the Bose. I would assume they do it the same though. I would think you could just open your trunk and remove one of your back speakers and see if there is an amp attached. Hope that helps some.
'97 CL with custom scratches thanks to my mom's "wonderful" cats
I want to say that the stock amp in located in the deck itself with the bose system. Otherwise, why would the deck get so hot during continous play, decks do not contain much else, other than amps, that produce heat. I have so far been unsucessful in locating the amp elsewhere, but I did notice if you trace the wires from the rear of the deck, they go down into the center console and under the passenger seat, not into that little black box, cause that is not an amp, but that does seem to be where the wires travel. I have my guy at my local shop looking into it for me, so if I find out more I will keep you all informed.
1997 ACURA 3.0 CL PREMIUM
Apex-i cat-back Exhaust, AEM Intake, Clear Bumper Lenses, 18" ADR Cyrax rims, Ground Control Coilovers, Wings West Chin Spoiler, Acura Rear spoiler, Piaa Fog Lights, Tinted Windows, Boston Acoustics tweets, mids and subs.
Hi Hi,
The Amp is located in the trunk near the jack just like the CL-S. However, any idea about which wires I can hook up with an audio signal through the Amp ?? If someone has a Helm manual, that will help.
Thanks !!
E50
3.0CL
Eibach springs
Thanks !!
E50
3.0CL
Eibach springs
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
