CL: Bose compatible
Old Apr 2, 2011 | 05:07 PM
H's gray 03 CL type S's Avatar
Bose compatible
I'm looking into buying a double din nav head unit for my 03 CL-S but someone told me in order to install the head unit i would have to run all new speakers through my car is that true? And if so are there aftermarket double din nav units that are compatible with the factory Bose speakers?
Old Apr 3, 2011 | 08:42 PM
Rapture's Avatar
I made a thread about this as well, it's just a few spaces down.
If I get a response, I'll let you know. All I know right now is you either get new speakers or buy an adapter to help with the wiring, I believe.
Old Apr 10, 2011 | 09:39 PM
It'd be nice if someone who knows the answer or has had this problem to reply cuz it seems i'm not the only one asking this question
Old Apr 24, 2011 | 12:10 AM
kove01's Avatar
7th Gear
buy the pac-soem4 interface & you'll be able to mate up any aftermarket HU to factory wiring harness. pretty simple hookup. i just went thru all of this about a month ago.
no rewiring was needed, just had to jump the amps remote wire to the 12v acc wire from harness.
Old Apr 24, 2011 | 04:56 PM
AnthraciteTypeS's Avatar
6mt swapped..smart
I recently installed a double din and whoever told you that couldn't be further from the truth. All you're gonna need is a dash harness which you can get on ebay for $5. This connects to the back of the double din and connects through a plug to the factory everything (speakers, amp, etc) As for the nav add on module, I can't comment on that as I didn't add nav, but you may need to run an antenna for that which would be the only difference. To sum up, all you need is: the unit itself, a dash harness, and the dash kit (metra, or something comparable). Hopefully my response wasn't too late
Old May 21, 2011 | 12:47 AM
smACURAssCLS's Avatar
The problem with using just a harness is you are now sending a speaker level output from a more than likely high power radio to an amplifier. You will eventually damage the factory amplifier. Using the SOEM-4 you can reduce the speaker level to line level and avoid any chances of the Bose amplifier producing engine whine. You can also purches a harness made for the RSX that has RCAs made by Metra instead of speaker wires, but like I mentioned before, you might end up with some unwanted sound.
Old Jun 3, 2011 | 06:21 PM
860blackCL's Avatar
4th Gear
I have Alpine navi sittin in MA closet that I been dying to drop in MA 2003 cl s-type wit navi! But I was told I could not install nothing in there becuz my factory controlled MA ac/heat settings but I seen on here sum1 managed to accomplish it!??? I wanna do the same any ideas on WAT EXACTLY I NEED???
http://www.onlinecarstereo.com/CarAu...NA-W900BT.aspx
Jul 16, 2017 07:33 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
lanechanger
Oct 13, 2015 10:56 AM
adreano17
Sep 29, 2015 08:48 AM
