Blew Amp, Need Recommendations
Moderator Alumnus
If its not one fucking thing, its another with this fucking car. I was playing it wayyy too loud, for wayyy to long. It would normally turn itself off before any damage was done. But this time, it didn't make it. Its now making hissing noises, and sound is inaudible.
To make a long story short, I need a 5 channel amp that can push the following:
2 focal utopia 165ws
2 Eclipse Aluminum 88120s
2 Focal Audio6m (rear fill)
I'm currenly running 4 gauge wire.
Any suggestions?
Figured I'd post it here for some traffic before this gets moved over.
Any suggestions?
Full-Time IDIoT---DoH!!!
bro
sorry 2 hear that![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
In my car i have an mtx thunder 4405 amp I've had it since july and so far no problems...its a 5channel amp and i would recommend it to anyone interested in one...
heres a link (ignore the price, u can get it 4less):
https://www.onlinecarstereo.com/cara....asp?sku=11545
sorry 2 hear that
yeowwwwwwwwwwww..
that sucks man....but look at the bright side, now u can get a better amp![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I thinkkkk u had the Soundstream amp with 50x4 +100watts,...
anyways, here is the PERFECT amp for you
http://www.usamps.com/products/inv/usa-5600x.htm
USamps, very good amp, EXTREMELY UNDER-RATED, low THD, built like a TANK.
I have two new USamps sitting here in front of me....waiting to get installed in my car![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I would definetly get the 5600x, it seems perfect for you, and it will sound better than your old Soundstream Rub...
the specs on it are
75 Watts x 4 and 200 Watts x 1 into 4 Ohms
which is VERY under rated...i would suspect it would be more like 120 x 4 and 320 x 1
If you call USamps they will tell you the TRUE output of their amp.
i have a USA-600 that is rated at 600 watts x 1 @ 2ohms, but its REAL output is close to around 870 watts of CLEAN power @2ohms.
all in all, this amp looks pimp in chrome, and will power everything u have...much better than the soundstream u had bro
good luck,
for best prices on the USamps this place was ok, they have good service too
http://speedsound.com/ ask for Normad, or something like that...tell him Amir from toronto referred u...he might remember.
i got a IDMAX and my focals from him.
Jizzal is right, two amps would be better, i would go with a Tube amp for the focals, i heard Tube+focals sound AMAZING.
the specs on it are
good luck,
Moderator Alumnus
Originally posted by Crazy Sellout
why a 5-channel? Why not get 2 amps? Be easier to choose from.
Moderator Alumnus
ended up going with the soundstream D’Artagnan 5.1 for dolby surround sound.
• 0.02% THD
• 6 Channels
• RMS @ 4 ohm 65 x 5 + 200 x 1
• RMS @ 2 ohm 100 x 5 + 400 x 1
• RMS @ 1 ohm 500 x 1 (sub only)
I really wanted a soundstream tarantula 800 watt 5 channel amp, but no one with any reasonable price had one available. Ohh well, fuck it.
• 0.02% THD
• 6 Channels
Moderator Alumnus
fuck it, I changed my order to the tarantula I originally wanted
![](http://carstereotime.com/soundstream/images/tarantulaamp.jpg)
Etronics.com is the shit, no hassle at all.
RMS @ 4 ohm: 50 Watts x 4 + (sub) 200 Watts x 1
RMS @ 2 ohm: 100 Watts x 4 + (sub) 400 Watts x 1
RMS @ 4 ohm (mono): 200 Watts x 2 + (sub) 400 Watts x 1
It won't blow me outta my pants, but it'll be all I need.
EDIT: Stereoheads, what decides what ohms you are running at?
Turn Signals are good!
what determines what ohms you are running at is what speakers you are using... how many and what ohms each one is.
The Eclipse 88120.... lemme guess, a 12" DVC sub that has 2 - 8 ohm coils?
Moderator Alumnus
say CLS-D, we need to hit up the spot down in lower greenville sometime and get fucked up and get on some hoes or somethin'.
Moderator Alumnus
so here is one more quick question... since its a 5 channel amp... obviously the speakers have different ohm ratings...
how do I ask this...
say I have 2 speakers with 4 ohm coils, and 2 speakers with 8 ohm coils... will the amp run at diffrent ohm settings? or will it just default to whatever the highest ohm rating is (8 ohms)?
Are you using the 88120's that are 4ohm DVC or are they 4ohm SVC? Which speakers are you referring to that are 8 ohm? If I am not mistaken the Audiom 6 mid is a 6 ohm driver and the 165w's are 4ohm's.
The speaker's themselves and the way they are wired decides what impedance the amp will see (Basic explanation).
If you go with that Tarantula it would run like this:
channels 1+2 = 4ohms for the 165w's
channels 3+4 =6 ohm's for the Audiom's
and depending on which voice coil's your subs have you could either have a 4ohm or 1ohm load if they are 4ohm DVC subs or you could have either 8 or 2 ohm loads if your pair of subs are 4ohm SVC.
Hopefully you have the SVC subs and you can run them at 2ohm's since those subs are asking for 500w rms each. I would really recommend getting two seperate amplifiers as well each with it's own fused connection. This will save your amps from being fried in the future. Please for the love of god tell me that you have a proper fused connection to the battery for this Tarantula...
How much are you paying for that amp? If you are interested in a dual amp setup, my brother has this set for sale : http://www.phoenixgold.com/webfaq/M_Special.htm
Hope this helps. let me know if you have any questions.
Amir,
Hey buddy how's it goin'? I just wanted to tell you that I did not forget about our agreement
. I will be leaving for CES this Thursday. I will let yo know the details as soon as I get back!
Bryan
Amir,
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Bryan
Originally posted by mantis23
Thanks for the response SKWCL...
Moderator Alumnus
Ahh yes, that answers my question. Thanks a million. I have the 88120 DVCs though, not SVCs. I believe I do have the proper battery (optima blue), PG cap(dunno if it even helps), and fuse setup for the tarantula. Hopefully I won't blow it again. If I do, its back to the drawing board. ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
I got the amp for 529.99 + overnight shipping.
![](http://www.thefiresauce.com/Mantis/images/DSC01712.jpg)
Amir,
Bryan
Amir,
Bryan
Moderator Alumnus
Well, I keep gettin dicked on my amp...just got this email
Dear Customer,
Due to an error in our inventory the Soundstream TR8005 appeared available, however we could not locate the product in our warehouse. We are sorry for the delay and the inconvenience your have experienced. We have contacted Soundstream but right now they do not have the item in stock nor an expected date of delivery. Please advise what you wish to do.
Thank you
Nancy Levy
Etronics
Looks like I may have to go with 2 seperate amps..![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
All I should have to do is run a new + cable to the rear, get a new ground wire somewhere in the back, & splice into the remote, right?
This sucks, I haven't had tunes in the CL-S in damn near 2 weeks.
Dear Customer,
Thank you
Nancy Levy
Etronics
Are you interested in those PG amps I mentioned? You could wire it like this:
Outlaw 1845:
Channels 1+2 to your 165W's for 85w x 2
Channels 3+4 bridged for 500w x 1 at 4 ohms for your subs
Bandit 1895
Both channels to your Audiom 6's for a little less than 85w x 2 at 6 ohms.
Let me know. bso1@shaw.ca
Bryan
Outlaw 1845:
Bandit 1895
Bryan
Dear Customer,
Thank you
Nancy Levy
Etronics
Dear Customer,
Thank you
Nancy Levy
Etronics
Moderator Alumnus
Outlaw 1845:
Bandit 1895
Bryan
Outlaw 1845:
Bandit 1895
Bryan
I was also lookin' at the Phoenix Gold ZX600Ti & ZX400Ti. Decisions decisions... :/
InFaMouSLink
10-30-2015 09:43 AM
adreano17
09-29-2015 08:48 AM
