Best way to splice heavy gauge wire?
How do you guys splice together 2 pieces of heavy guage wire?
I've tried various different things over the years and never come up with anything I thought worked terribly well.
Let's say you have 8 gauge wire...
Retired. Not available.
when you said splice 2 wires, you meant connect them as one right? If this is the case, they have some huge connectors (up to 4 gauge). All you have to do is remove the insulation, stick the bare wire in the connector then use a vise or a hammer to crimp it.
I use a Western Union Splice. Pics near the bottom of the link. You can solder it to improve the physical strength and electrical continuity of the connection.
http://www.tpub.com/neets/book4/12a.htm
What I do is put them end to end and soilder the connections and use Heat Shrink Tubing over the wires and touch the ends up with Liquid Electrical Tape for a perfect seal.
SUPRMN84
10-07-2015 09:46 PM
