Best Subwoofers
there is no such thing as a best subwoofer. it depends on what you are looking for in a subwoofer
http://caraudioforum.com
Orion
Registered User
Originally Posted by htownaccord
i have the JL 12w7 w/ the JL 1000/1 .....everyone thinks my car hasl ike 3 12's in it when this sub hits....it also has great sound quality in the right box.
I need 2 more gears
I have 2 Orion 12" DVC's 1500 watts a piece. I have my gain turned down all the way and my headunit's bass setting turned down all the way. It is overpowering still with the factory door speakers. Blose just doesn't cut it with car audio. The subs are unbelievable they hit extremely hard and are very clear no distortion, but if you getting big powerful subs I would replace speakers and headunit too. Best brands are Orion, Eclipse, JL Audio and Kicker. You can't go wrong with any of those brands. You should specify what kind of music you most listen to and how loud do you like your bass to be. Do you like it to hit hard, boom or a bit of both? How much space are you willing to depart with in your trunk. 2 12's in a sealed box take up half the trunk just about. One 12" wouldn't take up much space.
im running 2 12" Incriminator Audio Lethal Injections and i feel like my car is falling apart... and by no means am i saying these are the best subs out..
theres a top of the line from that company called the Death Penalty which i hear is pretty nice..
Boomer SOONER
you really wont go wrong unless you go very cheep...you get what you pay for. But if you arent looking for really hard core bass, then the JLW7 and the like are way overkill for you.
yeah im looking for good bass...mainly for rock, heavy metal, i want to feel the bass drums hit, i like nice clean bass, something that i will feel, but not so much that my car is having a seisure...also im loooking for mabey just one 12 or 10"....need room for the rugby equipment.....thanks for the info tho.....Jim
Boomer SOONER
yeah, there is no best sub out there. It's all subjective. But if you want a good quality top of the line sub, do some research. The best ones will be evident. It took me a couple months to decide. There are a lot of variables to consider: Cost, What kind of car it's going into, How much trunk space do you want to sacrifice, what kinda music do you listen to, do you want sealed or ported, do you want room to upgrade in the future i.e. do you want to be able to make your system louder, do you care about the weight of the system. My sub weighs about 60 pounds alone. I decided on a 15" RE XXX. You can check my system here: https://acurazine.com/forums/car-parts-sale-361/comptech-sale-101684/
Also you should consider an amp while your looking for a sub. you should kinda pick them out at the same time to know exactly what voice coil config. you need to buy. By knowing what amp you are getting, you will know exactly how you can and can't wire the sub and how many watts you will get at what ohm load. Here's some advice, definitely get a DVC(Dual voice coil) subwoofer, no reason not to, it's only a few bucks more then an SVC and you will have more wiring capabilities and be able to upgrade.
Let us know if you have any other questions.
I have 2, 10'' alpine typwe r's, and they kick man. I also have 2 mtx 800 watt amps one for each sub with a power cap. They enough power to power 4 of them i think. Also anyone know places to find custom painted wheels. I love the foose speedster 19's, but i dont want chrome, i want to customize it that much further and have them painted to match my white diamond '04 TL. Any options or ideas. I want to keep the chrome lip but have the 4 spokes custom done.
Thanks for all the input guys. And yeah im looking at prabally just one 12" i need the space for all my rugby, soccer, and snowboard equip. And im looking for a powerfull sub, mainly ill be playing heavy rock, so im thinking a sealed box. And im looking at kicker or mabey a JL w3v2. But i still have time to research but thanks for all the help. Jim
There is only a good subwoofer for YOUR TYpe of music. The box is what really matters in these installs anyways. All the subs that everyone is listing are good for the most part.
If you want a sub that POUNDS, you should go with the Image Dynamics IDMAX12.. that thing can take 1000W RMS all day long... and sound quality is top notch. but again everything is good just get a real good box built and you are all set.
Ryan
Ryan
9.5+10.5 22m=Hella Flush
Originally Posted by yunginTL
ALPINE TYPE R 1500WATT 15"Z BANG LOUD AS HELLLLLLLL. u go to mobile one n the loudest shit they got r type r'z thz wuz goin in my foreign
I have a pair of Alpine DVC Type R 12's and they boom really hard and tight. Very impressive sub I must say. I was thinking of selling my pair 12's and buying just 1 15 Type R sub. WOuld you think 1-15 Type R will sound better in terms of SPL than my pair 12's????
The Alpine Type R, although a quality subwoofer, are far and away from being the loudest ones out there. Oh, and by the way, they handle 500 watts RMS. I hate when people quote peak wattage numbers when referring to amps and speakers.
Back to the subject at hand. There are many quality subwoofers out there. Generally, as with most things, you get what you pay for when it comes to subwoofers. Some are a better value than others, but you get my point. One item that you shouldn't skimp is wiring. Get some quality patch cable and speaker wires.
Also get a well matched quality amplifier, one that has a power output approx. the same as the sub, in terms of RMS watts. Another item, as has also been mentioned previously, is good solid box. The three main types of boxes are sealed, ported, and band-pass. They all have their pro's and con's. Certain woofers are designed for use in specific types of boxes. Others can perform well in a wide range of boxes. Personally, I prefer the sound of a sealed box setup. The tighter the bass, the better, IMO.
If you want a decent amount of bass without taking too much room, go with a small sealed enclosure matched with a sub designed for such an application. Look for a sub that requires a sealed box volume of <1.0 cubic feet. Rockford Fosgate, Kicker, Alpine, JL Audio, among others all make good subs that fit this criterion.
Alot of these systems sound extreme. Are you trying to have enough bass for you, or your neighbors, people in the streets, cars next to you and around you, and in some cases, anyone within a half mile radius of you?
Stick with a sealed box and a reasonably priced system. The more money generally the better stuff. I have sold countless systems and every speaker has it's advantages. JL W7's are great subs but not the best on the market. Sometimes the smaller names give you more bang for your buck. I have heard good feedback about Alpine Type X's and some underground brands like Massive audio (reasonably priced bump). Every person has their own opinions which are generally based on brand preference.
yeah i just went to Tweeters today and got a whole system set out(speakers, subs, amp,RCA's, wirings) it came out to about $1200, for all Boston Acoustic Speakers, one 12' JL W3V2 in a sealed box, alpine amps for sub and speakers, and an alpine HU. Very nice system. He also mentiond he could make a conceald sub box on the side of the trunk, but thats $500. So all i have to get is the money, and im set.(im sure i can save money tho by searching around to find the parts for alot cheaper)
Boomer SOONER
Ya that store isnt known for cheep prices, they usually have MSRP prices, but sometimes you can get a total package deal. In other words, you can talk them down. Another way is if you can get cash. I wouldnt get the sub on the side of the trunk for sound level purposes and SQ. Those subs are pretty good also, I have 2 of them with 350 watts/sub and it hits real hard, Ill probably drop down to just one when I get all grown up...damn thats pretty soon actually
You might want to get a ported box with only 1 of those subs...it will play louder than sealed, but you will lose some SQ. Just depends on what you want.
yeah tweeters is def. a very expensive place, but very nice. And im not looking for really loud and not looking to shake windows with the sub, just looking to fill out the sound levels and have some kick.
AndrewS
19
03-14-2024 06:59 PM
BoricuaTL
04-08-2016 01:08 PM
kb1rl
09-30-2015 10:17 AM
3GTLOwns
09-09-2015 09:51 PM
