best subwoofer to get
sorry if this has been covered but I had 2 12inch Rockford Fosegate subwoofers in my trunk...one blew...replaced it. The other one blew....kept the other one in and now that one blew. So needless to say I'm not a fan of Rockford Fosegate now. Any recomendations on what kind i should get now?
Received 1,080 Likes
Might want to address the issue causing your subs to blow before sinking more money into the woofers.
What amp are you running for the subs? What are the specs on it?
2001 CL Type S
Originally Posted by TkdIceMan
It might be your amp that is killing your subs. And SPL = (Sound Pressure Levels)
The hot trend right now, and subs can be trendy, is the Alpine Type R. It's fairly inexpensive, has good sound quality (not great, but very good), hits hard and doesn't require massive amounts of power; 300 - 500 watts will certainly be enough to do it justice. The Caraudio.com forum is an amazing resource.
RickRoush03
i had the infinity 10.1d 350rms, blew 2 of them, not sure if it was b/c i had 420rms going to them but now have the alpine type r, its hit but its not as loud as the infinity, seems like it can really use all 500rms it says it can handle.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by hornyleprechaun
SQ = sound quality SPL = don't know but i know it essentially means Hits Harder
El Presidente
I would step back a second and think what exactly you want ot acheive with your system (SQ or SPL) and then take a look at the amp. Maybe upgrading the amp and then going with the Alpine Type-R's as mentioned above would be a good route for a solid and rather inexpensive setup
The jack hammer wouldn't fit in the trunk without a box That bad boy is huge!
I say turn down your gain! If you're running 12" fosgates in to the ground, you must be killing your ears! Blowing a 10" speaker every once in a while is one thing, but consistantly blowing 12s means that you are way too def to know the difference between loud and really fkn loud.
contrarian in fashion
hahaha ya.. pimp my ride is cool... not to the fact of how the cars end up (cause i think they look like shit) but its good entertainment. they make a box for it???? holy shit!
AndrewS
19
03-14-2024 06:59 PM
BoricuaTL
04-08-2016 01:08 PM
kb1rl
09-30-2015 10:17 AM
3GTLOwns
09-09-2015 09:51 PM
