Best subs for tight, articulate bass response?
Old Jun 26, 2006 | 10:32 AM
CQ7String's Avatar
metalguitarist.org
Over the weekend I put a sub/amp in my 2001 CL. The sub is a Kicker CompVR 15 DVC that I had laying around, and the amp is a mono kicker ZX750 with the remote bass control knob mounted in my glovebox.
So I have bass now. LOTS of bass. I'm keeping the stock deck, all I really wanted to do was fill out my system a bit and I've done it. It sounds really full if I'm listening to pop/dance/rap, but the problem is that I listen to 99.999% heavy metal, and the 15 is just way too boomy of a sub for the tight bass that I'm looking for.
I'm considering a pair of Orion 10's in a sealed box, since my experience with bandpass has always been that it's not quite tight and articulate enough.
Thoughts?
Old Jun 26, 2006 | 10:49 AM
m733l's Avatar
10's are definitly the way to go for your setup. since you have the zx750 i would get two10's in a seal box. you will get the tight response and still be loud when you need it.
Old Jun 26, 2006 | 06:09 PM
CivicEx1998's Avatar
How are the sub faced? To the trunk, rear seats or upward?
I too found that 15 are very boomy specially in the car with a closed trunk (EG. Sedans). I put the sub facing upwards and was suprised how much tighter, cleaner, the bass sounded and with much less of the boom.
Old Jun 27, 2006 | 08:22 AM
paul_huryk's Avatar
Pleasure Unit
My experience with subs tell me that you will need a few things to have tight bass:
10" sub (maybe a 12" if its meant for a really small box)
Sealed box - usually about 1cu ft
High quality sub - talking about accuracy, not price
I have 2 10" DLS magnesium subs in a sealed box in my TL-S, super tight, yet rumble like the "sloppier" 10" subs when they need to.
Old Jun 28, 2006 | 05:25 AM
DiaBando's Avatar
gistered User
I put Infinity's 10 in. Basslink in my son's honda over the winter. Good, tight bass. Smaller space though.
Old Jun 29, 2006 | 12:14 AM
flaw-ls's Avatar
JL Audio 10w3v3's sound great. i would go with a sealed enclosure, it will give you a wider range in bass instead of just anything lower than 35 hz. your looking for more 45-55 hz so that all the music you listen to hits every bass note.
Old Jun 29, 2006 | 08:51 AM
paul_huryk's Avatar
Pleasure Unit
One additional thing to note that not only is a sealed box "tighter" sounding, but it also has the most flat frequency response of any enclosure - just that it won't be as loud. A ported box is louder at frequencies above the port tuning frequency, but produces little output below it (distortion is a major issue). Bandpass boxes are "double ported" meaning that they are tuned for a narrow range of frequencies, but have little output below and above those 2 frequencies. They are all output maximum volume.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
