Belly-up, boys! Need hands-on TSX wiring help
I've run new speaker wire thru the molex on the TSX drivers side-but where do you snake the wire thru the body? I know its a pokie-feelie kinda thing. Yeah, there's a simple plastic cover over the hole, like the passenger side-- but I can't work the wire thru the hole. Left? Right? Up or Down? Anybody?
Don't really follow you. I ran new wire through to the passenger's door, but never encountered a plastic cover - are you referring to the rubber boot that goes over the factory wire harness? The passenger door wire harness connects inside the car, so the boot is unobstructed, the driver's door however connects at the door and I wasn't able to run new wire through it. If you have some pics, I'd like to see them, I would like to be able to get some wire to the driver's door.
Is this what you mean (pass side):
Wow! I got the snake thru! I new it would go eventually-but 3 hours of probing. Sorry, guys. I was referring to the hole on the chassis that leads to the side of the dash/interior of the car, from the DS door. I drilled/enlarged a square available on the 'blue' block plug/connector, on the DS door itself--and the corresponding white connector, which leads to the interior of the DS door (Non-Nav 05 TSX). Similar to the 12Volt tutorial here:
http://www.the12volt.com/installbay/...TID=78731&PN=1
Originally Posted by Spoon
Ah. Didn't think it was possible without drilling a hole. Thanks for the link.
I'm back. To see clearly the where-to-drill opening on the blue connector; I used a short length of heavy duty trimmer line to clean-out the insulation 'Goop' blocking the path. Believe me, it was not difficult. Just take your time. I'm moving on to post on an easy way to 'line up' your new speakers and spacers to the door panel speaker opening-without putting the door panel on 'n off til they line up.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
SUPRMN84
Oct 7, 2015 09:46 PM
