Is it bad to underpower a sub?
Old Mar 28, 2005 | 10:24 AM
Red-CL's Avatar
Doin' da crack shuffle
Question Is it bad to underpower a sub?
If you have a sub that's 1000 watts rms but you're amp is only giving it 500 watts rms is that a bad thing.
What are the pros and cons of doing this?
Old Mar 28, 2005 | 10:26 AM
jiggaman's Avatar
I spend 2 much time here
underpowering can blow an amp i believe, because you are making it work too hard.
Old Mar 28, 2005 | 10:42 AM
blumpkin's Avatar
o-qua tangin wann
amp clips ---> distortion ---> blown sub(s)
i dunno of any pros
Old Mar 28, 2005 | 10:52 AM
ou sig's Avatar
Boomer SOONER
ya it is worse to underpower than overpower (but not really for a sub), you need to give what sub and amp you are talking about. RMS rattings really dont mean much at all. Also what kind of box do you have and what kind of volume levels are you wanting to go for?
500 watts is really plenty to run just about any sub (not the SoloX ) but most other subs regardless of the subs RMS ratings. so you should be just fine
Another way of looking at it - underpowering a sub slightly or getting the amp to clip is sometimes just fine for a sub. You really have to worry about blowing mids or tweeters with underpowering and sending them cliping sound and distortion. It is not that big of a deal for a sub at all. So beetlejuice dude isnt correct at all.
Old Mar 28, 2005 | 04:19 PM
blumpkin's Avatar
o-qua tangin wann
overdrive the amp and it will clip
Old Mar 28, 2005 | 04:27 PM
ou sig's Avatar
Boomer SOONER
no shit, I never said it wouldnt, I just said its not that bad for a sub, but it will blow your mids or tweeters much faster.
Old Mar 28, 2005 | 05:43 PM
elduderino's Avatar
VP Electricity
You are not hurting your woofer, you are NOT underpowering it, you are within its power rating.
Power Handling is NOT efficiency. How much power you can handle is NOT how much you need!
If you clip your amp, you will hear your subs make bad noises. If you can't hear the noises, you shouldn't have subs : )
hrothgar02
Nov 2, 2015 01:29 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Timmy18
Oct 17, 2015 03:58 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hrothgar02
Sep 28, 2015 11:08 AM
