Audio and Speaker Question
Guys,
I am trying to put together a Kick ASS stereo system. Right now I have a PPI 2 Channel AMP and 1 12' woofer. I am calling on all your expertiese and knowledge of what Type of speaker I should put in the front and what amp I should use? MB Quart? Infinity comp? What do you guys think will give me the best Sound?
loud and clear...your probably want a sql setup.
components: since you like your music to be "CLEAR" you will want to get a set where the tweeters are made of hard material e.g. metal or graphite. Those will be bright and snappy. I might make your ears bleed but they're clear. As far as brands go, im not sure which ones are made of metal or graphite.
Subwoofer: you might want to look into resonant engineering
VP Electricity
1 Post
Originally Posted by TLBaller
loud and clear
Everybody says that.
OK, kid, first off, you have to pick a budget. If you don't I will recommend a $5000 system and then you'll freak.
Will you install it or will someone else (i.e., a shop?)
I would suggest going and listening to high end speakers and a home store - day Dynaudios, Thiels, etc. Give yourself a good reference of what's possible.
THEN I would look at some respected brands like DLS, Dynaudio, Morel, CDT, and even Focal (not my fave).
cannemt7, hopefully you are realistic and realize that a "kick-ass" system cannot be had for a few hundred $. you can get a better system for a few hundred $, if you shop wisely. by the way, what is a a "kick ass" system? extremely loud bass? extremely deep bass? precise imaging? expansive 3D soundstage? remember that a good install is as expensive as the parts, and often a good install can be 75 to 90% of the sound quality. go out and listen to as many systems as you can and then choose what really is a "kick ass" system to you. it will probably mean that you need to be like a lot of us and will need to save up more money thn we thought at first we would need.cheap and good are, typically, mutually exclusive, unfortunately. jps
I know a bunch of metal/magnesium alloy/etc tweeters that are smoother than most soft dome, and I know a bunch of soft dome tweeters that are clear sounding with some damn good top end extention.
My 1" Seas Protos are fabric type, yet they have top end shimmer and extention like most metal-type tweeters.
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
