Audio in to reciever from VCR
Old Oct 16, 2001 | 04:16 PM
JdawgCL's Avatar
Ok , i have a clarion head unit and it has a CeNet connection on back, but i was wondereing if there is any way i can get a audio in to my reciever with out using a tv tuner. This signal will be from a vcr. Do they have things which can take the rca signal and go through your antenna and use a frequency.
Any opinions?
Old Oct 16, 2001 | 05:50 PM
SumkidwithaCL's Avatar
Turn Signals are good!
Try getting a hold of Clarion, If I remember right they have a plug in adapter to allow for an auxillary input.
Old Oct 18, 2001 | 11:08 AM
rmstoico's Avatar
i like chicken
yes you can get an fm modulator but they are junk, they sound horrible. without an aux. input on your HU the easiest way is to run a t-splitter. it is basically an rca plug that splits from one to two. run the HU rca's into a splitter, and out from the splitter goes into the amps on one end and into the vcr on the other end. good luck. make sure the vcr has 2 audio channels or your will get a mono run. ok confused? let me explain (this is where all the useless electronic info comes in handy)
voltage signal runs concurrent and will travel 2 wways in a wire. if you have one rca out of the vcr the system will travel back through that one rca and recognize only one channel. even if the vcr is off, you will notice you are not getting a differentiated balance between your left and right, so make sure the vcr has 2 channels. also, you can not split that one rca because remember it will travel back through the split into the one channel.
Old Oct 18, 2001 | 06:39 PM
If you do that then you wont be able to control the volume! Duh!
Old Oct 19, 2001 | 09:07 PM
rmstoico's Avatar
i like chicken
yes you can. there is actually more than one way to do it too! duh!
if you want more info jdawgcl email me and i will tell you personally. it seems "sumkidwithacl" doesnt like my choice of body kit so he has a wise ass remark for everything i post. good luck bro!
Old Oct 22, 2001 | 12:00 AM
:sqntfawk:
Charles Bennett
Jan 28, 2018 08:53 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
