ASAP.....need help wiring up head unit
Old Apr 15, 2009 | 07:42 PM
sayfulhaqq's Avatar
I'm installing an aftermarket head unit, hooked up the head unit and tested out the radio, its turning on but there is no sound, even tried a using a cd. I tried searching to see what the problem is , perhaps to bypass the bose amp.
I'm going to be hooking up an amp with two subs, the car is a 2003 cl.
PLEASE HELP , installing as we speak.
Old Apr 15, 2009 | 08:04 PM
1hotcls6's Avatar
the12volt.com
Old Apr 15, 2009 | 09:36 PM
phipark's Avatar
Not Asian
try the a/v section in OT. There's a few threads on this.
Old Apr 15, 2009 | 10:04 PM
sayfulhaqq's Avatar
From the looks of it I have to bypass the bose amp , but I didnt have enough time as I was at a friends shop. Ending up putting the stock head unit back, till I can find out for sure.
Anybody have the wiring diagram needed to bypass the amp, the search revealed links but they were all dead, and this what I need to do?
Old Apr 15, 2009 | 11:44 PM
sayfulhaqq's Avatar
After doing a little more research I find I can get an LOC, however still have a couple questions.
There have been threads with people replacing the head unit , keeping the stock speakers and having them blow out later, can anybody confirm this. The LOC seems like a good idea, so I will be looking into getting one tomm.
Still curious if people have successfully bypassed the bose amp and could provide a wiring diagram and what needs to be done.
Old Apr 15, 2009 | 11:56 PM
BIGBOOMER77's Avatar
Socal
i have a jvc kdhd-r1 head with all stock speakers and a 10" infinity sub.....what you need is the right harness..... i had the same problem as you. check to see if your harness has the royal blue colored remote lead wire on it. i had a harness that didnt and didnt notice it. bought another one with the blue wire on it and booyakashaw i got sound.
the stock speakers are pretty good, just tune ur head right(dont send to much bass to em) and you shouldnt blow anything. o and i took the 6x9's out so i cant vouch for those...
Old Apr 16, 2009 | 08:11 AM
02CLNOS's Avatar
BIGBOOMER77,
So want your saying is that the blue wire from the Aftermarket wiring harness needs to be connected to the power antenna wire coming off the stock harness. Is that the on/off for the amp in the trunk?
Old Apr 16, 2009 | 09:57 AM
3srwild3's Avatar
5th Gear
I had the same problem too, and I too figured out that the remote turn on wire (Blue one) was not connected correctly.
On a side note - to add on and maybe get some help myself - after I installed my new head unit my turn by turn voice for the NAV stopped working - how can I get her back?
Old Apr 16, 2009 | 10:22 AM
Socal
Originally Posted by 02CLNOS
BIGBOOMER77,
should just be blue to blue.... i think remote antenna and remote lead might be the same if i remember correctly.... like on color coode legends it says "power antenna/remote amp lead" or something like that.
Old Apr 16, 2009 | 11:21 AM
wong05tsx's Avatar
Need more room in
power antenna will only give a 12v signal when the radio IIRC
Old Apr 17, 2009 | 09:46 PM
smACURAssCLS's Avatar
Hey guys, i just joined this forum. I just got a 2003 cls with nav and onstar under a month ago.
I actually work for a company that makes interfaces for cars with this type of problems. We actually dont make anything for this vehicle...but i just got my hands on detailed schematics for the 01-03 audio, nav, and onstar. Im hoping to be able to rip that crap Bose and onstar system out and still have audio from the nav and a standalone bluetooth. I might put some type of kits together. The electrical for nav on the car is different to nav with onstar. But if your just trying to get your radio hooked up with the factory Bose amp...Use Metra harness#70-1725. It will use the factory system using your radios rca output. Good Luck.
Old Apr 17, 2009 | 11:05 PM
sayfulhaqq's Avatar
Everything is workingg , installed the LOC, and its running beautifully. The driving experience is awesome. Thanks for everybody's replies.
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
