Anyone know where the Terminator Mod can be found?
Old Jul 26, 2004 | 03:04 PM
Rusky's Avatar
My baby's daddy
I read droves about the terminator and eq roll off mod nearly a year ago. I wanted to implement the temrinator mod but now I can't find it. Can someone direct me to it (the terminator mod, not the eq mod) or repost it?
It was essentially installing a resistor and small capacitr between the wires on each speaker.
thanks very much
Old Jul 27, 2004 | 08:09 AM
Iggy's Avatar
Rusky,
Run a search using southbound in the user name. That should start you off.
Iggy
Old Jul 27, 2004 | 10:34 AM
Incubus's Avatar
What does it do? Sounds cool enough for me to try it...
Old Jul 28, 2004 | 11:11 AM
Rusky's Avatar
My baby's daddy
I haven't yet found the post...
but what does it do?... I'm no expert but from what I gather, it helps to cancel transmission line effects. This is where the frequency of a wave matches the length of the wire and causes reflective interference of frequences... Again, I am no expert and my description may be flawed (please correct me if so!). This interference can be roughly translated to distortion or loss of the signal. The signal intended for the speaker gets partially reflected back to the source. The effect is probably minimal but, hell, I went through the trouble to run 14awg speaker wire into my doors because I couldn't live with the tiny amount of loss I might experience with 50 watts coming in (it is, apparently, quite small).
paraphrazed from http://www.allaboutcircuits.com/vol_2/chpt_13/1.html
Reflections may be eliminated from the transmission line (speaker wire) if the load's impedance exactly equals the characteristic ("surge") impedance of the line. For example, if a 50 Ω resistor is connected at the end of the 50 Ω cable, there will be no reflected energy, all signal energy being dissipated by the resistor.
I have many questions, I don't fully understand this... Anyone who can explain better, please do
Old Jul 28, 2004 | 12:51 PM
Rusky's Avatar
My baby's daddy
Found iT!
Full post
SouthBound's terminator mod components pic
Installed pic
southbound's words
terminator mod consists of a .05uF/1kv ceramic disc cap in series with a 100ohm/1watt resistor soldered directly across the overall speaker terminals. The polarity of either component does not matter, and this series soldered connection between the cap and resistor does not touch anything else. Next, solder the loose end of either the cap or resistor to one of the speaker terminals, and the other loose end of this RC network to the other speaker terminal. Again, polarity of any aspect of this series network does not matter.
It consists of a 100 ohm/1watt resistor and a .05uF/1kv cap wired in series and placed in parallel to the speaker (or crossover) across the speaker wires.
rock on
IBankMouse
Jun 13, 2020 12:53 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
STL TL-S
Sep 23, 2015 08:52 PM
eastcoastguy
Sep 23, 2015 06:29 AM
g1underground
Mid-Atlantic
Sep 23, 2015 01:18 AM
