Anybody like JL audio subs?
I have the 12W3-D4. My field is not car audio, so I don't know the difference between the W3 and the W6. I can say that my W3 is a very good sub, though. I have one 12" connected to a 250 watt RockfordFosgate amp and it delivers plenty of clear bass. I examined the sub before I had it put in; and compared to other subs I've seen in the past, the JL Audio sub is very good quality. I recommend it from my own experience with it.
I love JL subs. I have ran many set ups and not one has been a disappointment. The following are the set ups...3-8w6's, 2-10w1, 4-10w1, 2-15w1, 1-15w6, 1-12w3, 2-12w3.
Go to JL Audio's web site to find out more information on the differences between the w3 and w6 models.
I really like JL Audio subs. Had Rockford subs before but they didn't last that long.
JLs are made to play in smaller enclosures which is a plus. The difference between the W3 and W6 is the power handling, ohms and sound. The W6 has a bigger magnet which when hooked up to a capable amp will equate to better bass.
--Teflon
--Teflon
They rock. I had a single 10w6 in the trunk of my '97 Maxima SE hooked driven by a Kenwood mono sub amp. Very tight and will give you great lows to fill out the system. And if pounding is your thing, these things can pound.
JLs
They are good and cheap. You will be happy with them. They are also very common but if you want to go more unique then it will cost you more $$$.
There are very good subs out there that take out JLs in depth and clarity and are less common.
If you don't care about that, then JLs are the best bang for the buck (assuming you know where to buy). Again, you will be happy with them. I promise. Good luck!
I just put in a JL 12W3 tonight with a Kenwood Excelon KAC-X301T 300W/400W And it sounds incredible!!!! Tight, clean, and pounds like a jackhammer in you brain I love it !! Wooooooohoooooooo
i got my 2 10 w3's installed in june, and they sound great. got the rockford 500.2 powering them. a lot of bass for just 2 10's, and its clean and tight bass too. i might get more for my audi at school
navtool.com
31
11-16-2015 08:30 PM
InFaMouSLink
10-30-2015 09:43 AM
