Amp won't turn off
Old Feb 6, 2009 | 05:40 PM
nayaab88's Avatar
Amp won't turn off
OK guys. I installed my system and wired up everything and it works perfectly except that the amp will not turn off when i turn off the car and radio, the lights and power LED on the amp just stay on. I know the remote wire is good cuz I used with the stock sub mod previously. Even when i take out the remote wire it still wont turn off. I'm stumped, any ideas?
Old Feb 10, 2009 | 06:43 PM
Jonesi's Avatar
sounds like the power source you're using is a constant and is on all the time. have you tried a different source for that? Have you used a volt meter to double check the remote wire and your power?
Old Feb 10, 2009 | 07:48 PM
nayaab88's Avatar
ya the remote wire works fine, i checked it. I have the amp power cord connected directly to the battery using 8 gauge wiring. I didnt know there was another source i can use, any other sources are there?
Old Mar 4, 2009 | 12:42 PM
Newbee's Avatar
ur not putting a fuse on the power wire near the battery?
Old Mar 4, 2009 | 03:21 PM
pgapeles's Avatar
What kind of amp did u install?
Old Mar 4, 2009 | 04:46 PM
nayaab88's Avatar
The fuse is there and I have an Infinity 1300a.
Old Mar 14, 2009 | 12:35 AM
88ChevyBlazer's Avatar
Newbee: Fuses have nothing to do with it.
Nataab88: Your amp is messed up internally. Hit it with a hammer then buy a new one.
Old Mar 15, 2009 | 02:31 PM
Jonesi's Avatar
great way to help out members. calling them noobs.. :shakehead
Old Mar 15, 2009 | 05:12 PM
mattastick's Avatar
His comment was in response to this comment... Posted by username Newbee...
Old Mar 15, 2009 | 05:32 PM
nayaab88's Avatar
I'm going out on a limb when i say this.........MOD FAIL.
Old Mar 15, 2009 | 05:43 PM
Costco's Avatar
Jonesi.......
Old Mar 15, 2009 | 05:49 PM
Costco's Avatar
Check your head unit... make sure the constant and accessory wires aren't mixed up by testing them with a voltmeter
Old Mar 15, 2009 | 06:29 PM
nayaab88's Avatar
I think its the amp thats messed up cuz it stays on even when there is nothing connected to the remote port.
Old Mar 18, 2009 | 09:52 PM
03CL-S6SMike's Avatar
what amp is it?
nvm i missed the part where you stated it.. did you fix your problem yet?
Old Mar 19, 2009 | 02:29 PM
nayaab88's Avatar
Originally Posted by 03CL-S6SMike
what amp is it?
Nope not fixed yet. I just have a temp fix where i pulled the ground up behind the rear seats where the stock sub is. i glued a super strong magnet to the ground connector and now whenever i need to turn it on i reach back and stick it to the bolt thats right in front of the stock sub, i think its where you would hook up a kids car seat if you have one.
Old Mar 19, 2009 | 04:31 PM
Osamu's Avatar
haha, nice fix. Hopefully you don't damage the amp anymore than it already is by having to pull the ground all the time, or having a loose ground on like bumpy roads. Also i'd be cautious of like electrical fires. For some reason I keep hearing stories lately of people having fires in their car that it's made me paranoid enough to put a can of fire extinguisher stuff in my car.
definitely sounds like something is wrong w/ the amp though if it is on w/ nothing in the remote. I assume you double checked to make sure the power wire isn't jumping to the remote port in anyway. Thats the only way I could see it staying on all the time w/o a remote wire.
Old Mar 19, 2009 | 04:46 PM
nayaab88's Avatar
Haha ya I'm careful with watching the connection. I might just put in a toggle switch in the front by the dimmer. I don't really care if the amp gets any more messed up. I didn't know it could mess up if I kept pulling the ground, whatever. And ya, I made hella sure that the power wasn't jumping to the remote port.
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Pegon95
Sep 15, 2015 01:54 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
