TL: amp wont turn on
Old Apr 4, 2011 | 09:53 PM
JterrorC's Avatar
Always a Honda =Þ
amp wont turn on
soooooo...whoops....while testing speakers to see which wires were front,back, left and right...i had the power on..how else would i check....
so when all was said and done..the damn screwdriver phillips tip decided to slip off the screwdriver...it fell exactly on the ground and 12v screw....making contact on both...
now my amp wont turn on....the fuse on the amp didnt blow (never does..what is it for anyways?) and the fuse by the battery didnt either..wtf.. what should i look for ...i opened the amp and cant see anything wrong ...
Old Apr 5, 2011 | 12:36 PM
swllen_cu's Avatar
Amp is fried...
You should have done it the correct way by just hooking up one pair of speaker wires at a time and just marking them...
Old Apr 5, 2011 | 01:33 PM
JterrorC's Avatar
Always a Honda =Þ
i did.... do it like that...
Old Apr 5, 2011 | 05:22 PM
mattastick's Avatar
Shut the amp off whenever you mess with the connections... If you don't, you're asking for exactly what happened, which is a fried amp...
Old Apr 5, 2011 | 11:34 PM
JterrorC's Avatar
Always a Honda =Þ
anyone know how to mess with a multimeter?... how can i check the capicitors resistor transitors etc
Old Apr 7, 2011 | 10:24 AM
swllen_cu's Avatar
What I was trying to explain to the OP....
Old Apr 7, 2011 | 11:03 AM
fourthmeal's Avatar
Chances are the fuses ARE fried, but don't look like it. Replace them anyway, and retest.
mada51589
Jan 9, 2025 04:40 PM
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
